Hair Clumping Error #54774
Closed
opened 2018-04-23 17:13:16 +02:00 by Jeremiah Thornton · 9 comments
Mac OS Sierra 10.12.6 with Intel HD Graphics 6000
Broken: 2.79b f4dc9f9
The error with the hair particle system involves the clumping editor. In Blender versions of Windows,the hair particles are clean and behave like Example #1. However,for Mac OS,it's a whole different story. Instead of the slider behaving like it should,it makes the hair clump incorrectly like in Example #2. This really bothers me and I think it should be fixed.
To fix the error presented in the file below,I would suggest fixing the coding of the hair particle system.
Hair Error.blend
**System Information** Mac OS Sierra 10.12.6 with Intel HD Graphics 6000 **Blender Version** Broken: 2.79b f4dc9f9 **Short description of error** The error with the hair particle system involves the **clumping** editor. In Blender versions of Windows,the hair particles are clean and behave like **Example #1**. However,for Mac OS,it's a whole different story. Instead of the slider behaving like it should,it makes the hair clump incorrectly like in **Example #2**. This really bothers me and I think it should be fixed. # 1 ![Screen Shot 2018-04-24 at 9.11.08 AM.png](https://archive.blender.org/developer/F2975940/Screen_Shot_2018-04-24_at_9.11.08_AM.png) # 2 ![Screen Shot 2018-04-23 at 9.36.52 AM.png](https://archive.blender.org/developer/F2958654/Screen_Shot_2018-04-23_at_9.36.52_AM.png) **Exact steps for others to reproduce the error** To fix the error presented in the file below,I would suggest fixing the coding of the hair particle system. [Hair Error.blend](https://archive.blender.org/developer/F2958914/Hair_Error.blend)
Added subscriber: @JeremiahColeThornton
#54773 was marked as duplicate of this issue
Member
Added subscriber: @lichtwerk
Member
Are you sure you are examining the same files in Windows/Linux compared to MacOS?
Because when I open provided file on Linux, I get the same result as posted in picture #2.
The reason for some of the child particles appearing shorter than the parent particles is the Length ("length of child paths")
This was set to 0.8 in your file, and the threshold of 0.1 was causing 10% of the children being full length, the remaining 90% were only 0.8times as long as the parent particles.
If I set the Length back to 1.0 I get a result as posted in picture #1.
Is that what you meant?
Marking as incomplete for the time being...
Are you sure you are examining the same files in Windows/Linux compared to MacOS? Because when I open provided file on Linux, I get the same result as posted in picture #2. The reason for some of the child particles appearing shorter than the parent particles is the `Length` ("length of child paths") ![#54774.png](https://archive.blender.org/developer/F2971844/T54774.png) This was set to 0.8 in your file, and the threshold of 0.1 was causing 10% of the children being full length, the remaining 90% were only 0.8times as long as the parent particles. If I set the Length back to 1.0 I get a result as posted in picture #1. Is that what you meant? Marking as incomplete for the time being...
Oh,my God! I just realized that I made a mistake. I replaced the top screenshot with the correct one and I corrected the versions of Blender. Sorry for the inconvenience.
Added subscriber: @mont29
This might have been fixed since then (there were some threading issues in particle code), please check with a blender2.8 alpha build.
Bastien Montagne self-assigned this 2018-07-25 21:33:50 +02:00
Reference: blender/blender-addons#54774
