COW Operators: Object
Closed, InvalidPublicTO DO
Instructions
See T54810 for details
editors/object module
  • OBJECT_OT_location_clear
  • OBJECT_OT_rotation_clear
  • OBJECT_OT_scale_clear
  • OBJECT_OT_origin_clear
  • OBJECT_OT_visual_transform_apply
  • OBJECT_OT_transform_apply
  • OBJECT_OT_transform_axis_target
  • OBJECT_OT_origin_set
  • OBJECT_OT_mode_set
  • OBJECT_OT_editmode_toggle
  • OBJECT_OT_posemode_toggle
  • OBJECT_OT_proxy_make
  • OBJECT_OT_shade_smooth
  • OBJECT_OT_shade_flat
  • OBJECT_OT_paths_calculate
  • OBJECT_OT_paths_update
  • OBJECT_OT_paths_clear
  • OBJECT_OT_forcefield_toggle
  • OBJECT_OT_parent_set
  • OBJECT_OT_parent_no_inverse_set
  • OBJECT_OT_parent_clear
  • OBJECT_OT_vertex_parent_set
  • OBJECT_OT_track_set
  • OBJECT_OT_track_clear
  • OBJECT_OT_slow_parent_set
  • OBJECT_OT_slow_parent_clear
  • OBJECT_OT_make_local
  • OBJECT_OT_make_override_static
  • OBJECT_OT_make_single_user
  • OBJECT_OT_make_links_scene
  • OBJECT_OT_make_links_data
  • OBJECT_OT_select_random
  • OBJECT_OT_select_all
  • OBJECT_OT_select_same_group
  • OBJECT_OT_select_same_collection
  • OBJECT_OT_select_by_type
  • OBJECT_OT_select_linked
  • OBJECT_OT_select_grouped
  • OBJECT_OT_select_mirror
  • OBJECT_OT_select_more
  • OBJECT_OT_select_less
  • GROUP_OT_create
  • GROUP_OT_objects_remove_all
  • GROUP_OT_objects_add_active
  • GROUP_OT_objects_remove_active
  • OBJECT_OT_delete
  • OBJECT_OT_text_add
  • OBJECT_OT_armature_add
  • OBJECT_OT_empty_add
  • OBJECT_OT_lightprobe_add
  • OBJECT_OT_drop_named_image
  • OBJECT_OT_lamp_add
  • OBJECT_OT_camera_add
  • OBJECT_OT_speaker_add
  • OBJECT_OT_add
  • OBJECT_OT_add_named
  • OBJECT_OT_effector_add
  • OBJECT_OT_group_instance_add
  • OBJECT_OT_metaball_add
  • OBJECT_OT_duplicates_make_real
  • OBJECT_OT_duplicateT55247
  • OBJECT_OT_join
  • OBJECT_OT_join_shapes
  • OBJECT_OT_convert
  • OBJECT_OT_modifier_add
  • OBJECT_OT_modifier_remove
  • OBJECT_OT_modifier_move_up
  • OBJECT_OT_modifier_move_down
  • OBJECT_OT_modifier_apply
  • OBJECT_OT_modifier_convert
  • OBJECT_OT_modifier_copy
  • OBJECT_OT_multires_subdivide
  • OBJECT_OT_multires_reshape
  • OBJECT_OT_multires_higher_levels_delete
  • OBJECT_OT_multires_base_apply
  • OBJECT_OT_multires_external_save
  • OBJECT_OT_multires_external_pack
  • OBJECT_OT_skin_root_mark
  • OBJECT_OT_skin_loose_mark_clear
  • OBJECT_OT_skin_radii_equalize
  • OBJECT_OT_skin_armature_create
  • OBJECT_OT_correctivesmooth_bind
  • OBJECT_OT_meshdeform_bind
  • OBJECT_OT_explode_refresh
  • OBJECT_OT_ocean_bake
  • OBJECT_OT_constraint_add
  • OBJECT_OT_constraint_add_with_targets
  • POSE_OT_constraint_add
  • POSE_OT_constraint_add_with_targets
  • OBJECT_OT_constraints_copy
  • POSE_OT_constraints_copy
  • OBJECT_OT_constraints_clear
  • POSE_OT_constraints_clear
  • POSE_OT_ik_add
  • POSE_OT_ik_clear
  • CONSTRAINT_OT_delete
  • CONSTRAINT_OT_move_up
  • CONSTRAINT_OT_move_down
  • CONSTRAINT_OT_stretchto_reset
  • CONSTRAINT_OT_limitdistance_reset
  • CONSTRAINT_OT_childof_set_inverse
  • CONSTRAINT_OT_childof_clear_inverse
  • CONSTRAINT_OT_objectsolver_set_inverse
  • CONSTRAINT_OT_objectsolver_clear_inverse
  • CONSTRAINT_OT_followpath_path_animate
  • OBJECT_OT_vertex_group_add
  • OBJECT_OT_vertex_group_remove
  • OBJECT_OT_vertex_group_assign
  • OBJECT_OT_vertex_group_assign_new
  • OBJECT_OT_vertex_group_remove_from
  • OBJECT_OT_vertex_group_select
  • OBJECT_OT_vertex_group_deselect
  • OBJECT_OT_vertex_group_copy_to_linked
  • OBJECT_OT_vertex_group_copy_to_selected
  • OBJECT_OT_vertex_group_normalize
  • OBJECT_OT_vertex_group_normalize_all
  • OBJECT_OT_vertex_group_lock
  • OBJECT_OT_vertex_group_fix
  • OBJECT_OT_vertex_group_invert
  • OBJECT_OT_vertex_group_levels
  • OBJECT_OT_vertex_group_smooth
  • OBJECT_OT_vertex_group_clean
  • OBJECT_OT_vertex_group_quantize
  • OBJECT_OT_vertex_group_limit_total
  • OBJECT_OT_vertex_group_mirror
  • OBJECT_OT_vertex_group_set_active
  • OBJECT_OT_vertex_group_sort
  • OBJECT_OT_vertex_group_move
  • OBJECT_OT_vertex_weight_paste
  • OBJECT_OT_vertex_weight_delete
  • OBJECT_OT_vertex_weight_set_active
  • OBJECT_OT_vertex_weight_normalize_active_vertex
  • OBJECT_OT_vertex_weight_copy
  • OBJECT_OT_face_map_add
  • OBJECT_OT_face_map_remove
  • OBJECT_OT_face_map_assign
  • OBJECT_OT_face_map_remove_from
  • OBJECT_OT_face_map_select
  • OBJECT_OT_face_map_deselect
  • OBJECT_OT_face_map_move
  • TRANSFORM_OT_vertex_warp
  • OBJECT_OT_move_to_collection
  • OBJECT_OT_shape_key_add
  • OBJECT_OT_shape_key_remove
  • OBJECT_OT_shape_key_clear
  • OBJECT_OT_shape_key_retime
  • OBJECT_OT_shape_key_mirror
  • OBJECT_OT_shape_key_move
  • OBJECT_OT_group_add
  • OBJECT_OT_group_link
  • OBJECT_OT_group_remove
  • OBJECT_OT_group_unlink
  • OBJECT_OT_grouped_select
  • OBJECT_OT_hook_add_selob
  • OBJECT_OT_hook_add_newob
  • OBJECT_OT_hook_remove
  • OBJECT_OT_hook_select
  • OBJECT_OT_hook_assign
  • OBJECT_OT_hook_reset
  • OBJECT_OT_hook_recenter
  • OBJECT_OT_bake_image
  • OBJECT_OT_bake
  • OBJECT_OT_drop_named_material
  • OBJECT_OT_unlink_data
  • OBJECT_OT_laplaciandeform_bind
  • TRANSFORM_OT_vertex_random
  • OBJECT_OT_data_transfer
  • OBJECT_OT_datalayout_transfer
  • OBJECT_OT_surfacedeform_bind
Joshua Leung (aligorith) lowered the priority of this task from 90 to Normal.Apr 25 2018, 2:23 PM
Joshua Leung (aligorith) created this task.
Joshua Leung (aligorith) moved this task from Tasks to Doing on the Code Quest board.
Dalai Felinto (dfelinto) changed the status of subtask T55247: Duplicated objects transforms start at 0 from Unknown Status to Resolved.Jun 4 2018, 10:35 AM
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Nov 19 2018, 12:43 PM
Most operators appear to be working, and we will use bug tracker to handle remaining issues.
