COW Operators: Node Editor
Closed, InvalidPublicTO DO
Instructions
See T54810 for details
Note: Most of these are UI operators, but they may still require some careful checking
editors/space_node module
  • NODE_OT_properties
  • NODE_OT_toolbar
  • NODE_OT_select
  • NODE_OT_select_all
  • NODE_OT_select_linked_to
  • NODE_OT_select_linked_from
  • NODE_OT_select_border
  • NODE_OT_select_circle
  • NODE_OT_select_lasso
  • NODE_OT_select_grouped
  • NODE_OT_select_same_type_step
  • NODE_OT_find_node
  • NODE_OT_view_all
  • NODE_OT_view_selected
  • NODE_OT_mute_toggle
  • NODE_OT_hide_toggle
  • NODE_OT_preview_toggle
  • NODE_OT_options_toggle
  • NODE_OT_hide_socket_toggle
  • NODE_OT_node_copy_color
  • NODE_OT_duplicate
  • NODE_OT_delete
  • NODE_OT_delete_reconnect
  • NODE_OT_resize
  • NODE_OT_link
  • NODE_OT_link_make
  • NODE_OT_links_cut
  • NODE_OT_links_detach
  • NODE_OT_add_reroute
  • NODE_OT_group_make
  • NODE_OT_group_insert
  • NODE_OT_group_ungroup
  • NODE_OT_group_separate
  • NODE_OT_group_edit
  • NODE_OT_link_viewer
  • NODE_OT_insert_offset
  • NODE_OT_read_viewlayers
  • NODE_OT_render_changed
  • NODE_OT_backimage_move
  • NODE_OT_backimage_zoom
  • NODE_OT_backimage_fit
  • NODE_OT_backimage_sample
  • NODE_OT_add_file
  • NODE_OT_add_mask
  • NODE_OT_new_node_tree
  • NODE_OT_output_file_add_socket
  • NODE_OT_output_file_remove_active_socket
  • NODE_OT_output_file_move_active_socket
  • NODE_OT_parent_set
  • NODE_OT_join
  • NODE_OT_attach
  • NODE_OT_detach
  • NODE_OT_clipboard_copy
  • NODE_OT_clipboard_paste
  • NODE_OT_shader_script_update
  • NODE_OT_viewer_border
  • NODE_OT_clear_viewer_border
  • NODE_OT_switch_view_update
  • NODE_OT_tree_socket_add
  • NODE_OT_tree_socket_remove
  • NODE_OT_tree_socket_move
Joshua Leung (aligorith) lowered the priority of this task from 90 to Normal.Apr 25 2018, 2:53 PM
Joshua Leung (aligorith) created this task.
Joshua Leung (aligorith) edited a custom field.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Nov 19 2018, 12:40 PM
Most operators appear to be working, and we will use bug tracker to handle remaining issues.
