COW Operators: Transform
Closed, InvalidPublicTO DO
editors/transform module
What to do
Each of the conversion functions for different types of data in transform_conversions.c need to be checked and/or converted to use evaluated data. The changes needed are not always immediately intuitive: In most cases, you need to read current values from evaluated copy (since animation is applied there), then allow writing (by setting pointers in the td structs) to the original data.
Example Commits
Operators
  • TRANSFORM_OT_transform
    • Transform Tools
    • Modes
      • Object Mode
      • Pose Mode
      • Edit Mode: Mesh
      • Edit Mode: Armature
      • Edit Mode: Curves
      • Edit Mode: Grease Pencil (Todo for GP Branch only)
      • TexSpace
  • TRANSFORM_OT_select_orientation
  • TRANSFORM_OT_create_orientation
  • TRANSFORM_OT_delete_orientation
Joshua Leung (aligorith) lowered the priority of this task from 90 to Normal.Apr 25 2018, 3:24 PM
Joshua Leung (aligorith) created this task.
Joshua Leung (aligorith) triaged this task as 90 priority.May 25 2018, 4:10 PM
Joshua Leung (aligorith) moved this task from Tasks to Spring Bugs on the Code Quest board.
Joshua Leung (aligorith) updated the task description. (Show Details)
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to Normal.Sep 28 2018, 3:58 PM
Brecht Van Lommel (brecht) moved this task from Spring Bugs to Tasks on the Code Quest board.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Nov 19 2018, 12:41 PM
Most operators appear to be working, and we will use bug tracker to handle remaining issues.
