COW Operators: Other Geometry Types
Closed, InvalidPublicTO DO
NOTE: These operators are not ready to be ported yet. Refer back to T54810 for others
editors/curve module
  • FONT_OT_text_insert
  • FONT_OT_line_break
  • FONT_OT_case_toggle
  • FONT_OT_case_set
  • FONT_OT_style_toggle
  • FONT_OT_style_set
  • FONT_OT_select_all
  • FONT_OT_text_copy
  • FONT_OT_text_cut
  • FONT_OT_text_paste
  • FONT_OT_text_paste_from_file
  • FONT_OT_move
  • FONT_OT_move_select
  • FONT_OT_delete
  • FONT_OT_change_character
  • FONT_OT_change_spacing
  • FONT_OT_open
  • FONT_OT_unlink
  • FONT_OT_textbox_add
  • FONT_OT_textbox_remove
  • CURVE_OT_hide
  • CURVE_OT_reveal
  • CURVE_OT_separate
  • CURVE_OT_split
  • CURVE_OT_duplicate
  • CURVE_OT_delete
  • CURVE_OT_dissolve_verts
  • CURVE_OT_spline_type_set
  • CURVE_OT_radius_set
  • CURVE_OT_spline_weight_set
  • CURVE_OT_handle_type_set
  • CURVE_OT_normals_make_consistent
  • CURVE_OT_decimate
  • CURVE_OT_shade_smooth
  • CURVE_OT_shade_flat
  • CURVE_OT_tilt_clear
  • CURVE_OT_primitive_bezier_curve_add
  • CURVE_OT_primitive_bezier_circle_add
  • CURVE_OT_primitive_nurbs_curve_add
  • CURVE_OT_primitive_nurbs_circle_add
  • CURVE_OT_primitive_nurbs_path_add
  • SURFACE_OT_primitive_nurbs_surface_curve_add
  • SURFACE_OT_primitive_nurbs_surface_circle_add
  • SURFACE_OT_primitive_nurbs_surface_surface_add
  • SURFACE_OT_primitive_nurbs_surface_cylinder_add
  • SURFACE_OT_primitive_nurbs_surface_sphere_add
  • SURFACE_OT_primitive_nurbs_surface_torus_add
  • CURVE_OT_smooth
  • CURVE_OT_smooth_weight
  • CURVE_OT_smooth_radius
  • CURVE_OT_smooth_tilt
  • CURVE_OT_de_select_first
  • CURVE_OT_de_select_last
  • CURVE_OT_select_all
  • CURVE_OT_select_linked
  • CURVE_OT_select_linked_pick
  • CURVE_OT_select_row
  • CURVE_OT_select_next
  • CURVE_OT_select_previous
  • CURVE_OT_select_more
  • CURVE_OT_select_less
  • CURVE_OT_select_random
  • CURVE_OT_select_nth
  • CURVE_OT_select_similar
  • CURVE_OT_shortest_path_pick
  • CURVE_OT_switch_direction
  • CURVE_OT_subdivide
  • CURVE_OT_make_segment
  • CURVE_OT_spin
  • CURVE_OT_vertex_add
  • CURVE_OT_draw
  • CURVE_OT_extrude
  • CURVE_OT_cyclic_toggle
  • CURVE_OT_match_texture_space
editors/lattice module
  • LATTICE_OT_select_all
  • LATTICE_OT_select_more
  • LATTICE_OT_select_less
  • LATTICE_OT_select_ungrouped
  • LATTICE_OT_select_random
  • LATTICE_OT_select_mirror
  • LATTICE_OT_make_regular
  • LATTICE_OT_flip
editors/metaball module
  • MBALL_OT_delete_metaelems
  • MBALL_OT_duplicate_metaelems
  • MBALL_OT_hide_metaelems
  • MBALL_OT_reveal_metaelems
  • MBALL_OT_select_all
  • MBALL_OT_select_similar
  • MBALL_OT_select_random_metaelems
Joshua Leung (aligorith) lowered the priority of this task from 90 to Normal.Apr 25 2018, 3:39 PM
Joshua Leung (aligorith) created this task.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Nov 19 2018, 12:40 PM
Most operators appear to be working, and we will use bug tracker to handle remaining issues.
