Command Settings Cleanup
Blender has many settings that apply to commands. However, many of them are actually internal flags, and as such are not meant to be used by the end-user. We intend to clean this up. This document serves as an overview of the command settings we will remove from the user interface.
Text Objects
Typing
  • Remove completely. Don't allow redo. rBedf8bfe5fae179f0f0a6b5de43a96e0c926adae2
Paint/Sculpt Modes
Brush Select
Select
  • Remove completely. Don't allow redo. rBc8865f2c40fbe81c660fc3c7b1676b51af20ebf5
Add Grease Pencil Modifier
  • Remove completely. Don’t allow redo.
Object Mode
Delete
Mesh Edit Mode
Set Selection Mode (1, 2, 3)
William Reynish (billreynish) triaged this task as Normal priority.
Campbell Barton (campbellbarton) closed this task as Resolved.
Moved rotation XYZ axis to T55036
This is a bigger task and involves changing how rotation works internally, not so much settings cleanup.
Everything else on the list is done, closing.
