Crash when copying object with PointerProperty pointing to custom node tree
Broken: 2.79b
In our addon, materials have a PointerProperty that points to a custom node tree.
When this node tree contains nodes with custom sockets and a property of the socket was changed, Blender crashes when Ctrl+C is used to copy an object using the material in the 3D view.
It does not matter if the socket property was changed via script or manually.
  • Load factory settings
  • Open user preferences, install and enable the attached addon:
  • Open a node editor
  • Switch to the "Custom Nodes" tree type that was added by the addon
  • Create a new node tree
  • Create a new node
  • In the properties area, open the material properties and scroll down to the "Datablock ID Props Test" panel
  • Select the created custom node tree
  • In the 3D view, press Ctrl+C to copy the default cube. Blender crashes.
GDB session with Blender debug build:
Program received signal SIGSEGV, Segmentation fault.
0x0000000002b694d3 in blendfile_write_partial_cb (UNUSED_handle=0x0, UNUSED_bmain=0x7fffdebed608, vid=0x7fffd8b06a68) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/blendfile.c:569
569			if (id->lib && (id->lib->id.tag & LIB_TAG_DOIT) == 0)
(gdb) backtrace
#0  0x0000000002b694d3 in blendfile_write_partial_cb (UNUSED_handle=0x0, UNUSED_bmain=0x7fffdebed608, vid=0x7fffd8b06a68) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/blendfile.c:569
#1  0x0000000002a5b062 in expand_nodetree (fd=0x0, mainvar=0x7fffdebed608, ntree=0x7fffd8a27208) at /home/simon/programs/blender-git/blender/source/blender/blenloader/intern/readfile.c:9210
#2  0x0000000002a5d7c5 in BLO_expand_main (fdhandle=0x0, mainvar=0x7fffdebed608) at /home/simon/programs/blender-git/blender/source/blender/blenloader/intern/readfile.c:9908
#3  0x0000000002b695cb in BKE_blendfile_write_partial (bmain_src=0x7fffdebed608, filepath=0x7fffffffd840 "/tmp/copybuffer.blend", write_flags=16777216, reports=0x7fffc7701408)
    at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/blendfile.c:596
#4  0x0000000002b6768d in BKE_copybuffer_save (bmain_src=0x7fffdebed608, filename=0x7fffffffd840 "/tmp/copybuffer.blend", reports=0x7fffc7701408)
    at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/blender_copybuffer.c:81
#5  0x0000000001f96775 in view3d_copybuffer_exec (C=0x7fffe0087d38, op=0x7fffc7811e48) at /home/simon/programs/blender-git/blender/source/blender/editors/space_view3d/view3d_ops.c:95
#6  0x0000000001e4f71e in wm_operator_invoke (C=0x7fffe0087d38, ot=0x7fffd9db9488, event=0x7fffc7890288, properties=0x7fffcdac8f28, reports=0x0, poll_only=false)
    at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:1140
#7  0x0000000001e50e25 in wm_handler_operator_call (C=0x7fffe0087d38, handlers=0x7fffd89dea10, handler=0x7fffd8f64748, event=0x7fffc7890288, properties=0x7fffcdac8f28)
    at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:1782
#8  0x0000000001e5177c in wm_handlers_do_intern (C=0x7fffe0087d38, event=0x7fffc7890288, handlers=0x7fffd89dea10) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2062
#9  0x0000000001e51b3a in wm_handlers_do (C=0x7fffe0087d38, event=0x7fffc7890288, handlers=0x7fffd89dea10) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2173
#10 0x0000000001e5297c in wm_event_do_handlers (C=0x7fffe0087d38) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2508
#11 0x0000000001e462c7 in WM_main (C=0x7fffe0087d38) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm.c:504
#12 0x0000000001e41295 in main (argc=1, argv=0x7fffffffe0a8) at /home/simon/programs/blender-git/blender/source/creator/creator.c:527
(gdb) print id
$1 = (ID *) 0x7fffd8b06a68
(gdb) print vid
$2 = (void *) 0x7fffd8b06a68
(gdb) print id->tag
$3 = 32767
(gdb) print id->lib
$4 = (struct Library *) 0x6b636f5365646f4e
(gdb) print id->lib->id
Cannot access memory at address 0x6b636f5365646f4e
(gdb) print id->lib->id.tag
Cannot access memory at address 0x6b636f5365646fb2
The code where it crashes:
static void blendfile_write_partial_cb(void *UNUSED(handle), Main *UNUSED(bmain), void *vid)
	if (vid) {
		ID *id = vid;
		/* only tag for need-expand if not done, prevents eternal loops */
		if ((id->tag & LIB_TAG_DOIT) == 0)
			id->tag |= LIB_TAG_NEED_EXPAND | LIB_TAG_DOIT;
		if (id->lib && (id->lib->id.tag & LIB_TAG_DOIT) == 0)  // <- the crashing line
			id->lib->id.tag |= LIB_TAG_DOIT;
I suspect that id->lib is freed or not initialized, but not set to NULL.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.May 2 2018, 1:30 PM
Thx for the report.
Could you try a new master build from buildbot?
I havent checked code, but could confirm this issue in 2.79b. However in current master this seems to be resolved already?
Marking as incomplete for now...
I can confirm this, it is fixed in latest master.
I apologize for not checking earlier.
Will there be a 2.79c where fixes like this are backported?
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Resolved.Jun 20 2018, 3:19 PM
not sure if 2.79c will see the light, but closing this as it seems resolved
