Place object bug
Closed, InvalidPublic
Hello my name is pakasit i am thailand i don't know it's a bug or i don't know how to use it when i place my object it will Out of position from
my control i really don't understand about it can you help me please ? (If my words is wrong i most say sorry about to disturb)
Sincerely,
Pakasit
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.
Hi Pakasit,
For a valid bug report you need to show us how to reproduce your issue.
What exactly are you doing to place your object? What exactly happens when your object goes "out of position from your control"?
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
A guideline for making a good bug report can be found here: https://wiki.blender.org/index.php/Dev:Doc/Process/Bug_Reports
Marking as "Incomplete" until the requested information/data is provided.
Hello,
I think i should upload this file to show what did it look like. Here's my picture --->
i don't know it's a bug or i don't know how to use Blender (If my words was wrong i most say sorry about to disturb) "Incomplete"
Sincerely,
Pakasit
Hi Pakasit,
could you please attach a blend-file and exact steps to replicate your issue.
based on your image I first thought the issue was that your object's origin (the orange dot) is not near your geometry (Mesh data) - which would not be a bug. But if your object would be of type: "mesh", the tools menu would usually show more options. Also your objects name seems to only contain white-spaces - which probably shouldn't be a problem, but confused me for a second..
Hello blender supporter,
Can you made a video to teach me please ? i don't understand about
;-; (i'm stupid)
Sincerely,
Pakasit
like @Lukas Ziechmann (bl_cat) said, it looks like your objects origin is not near the geometry.
You can move the geometry in editmode or use an operator to move the origin (e.g. back to the geometry)
Please refer to the manual.
Note this looks like a general support issue and not a software error we can investigate.
For general issues, check on support sites such as:
If you still think you have found a bug, please upload your .blend file here (you can just drag and drop into a comment).
Closing.
