EXCEPTION_ACCESS_VIOLATION Blender 2.79 #54978
6 Participants
Reference: blender/blender#54978
Using Win10 64bit
Gigabyte GeForce® GTX 1050 Ti
Broken: 2.79
Worked: 2.78c
Closes on boot when running normally regardless of run as admin
Throws error "EXCEPTION_ACCESS_VIOLATION" when running from cmd
Only 2.79 is broken for me, every other version i've tried works like a glove
Added subscriber: @DerangedDerp
Added subscriber: @lichtwerk
Please:
Marking as incomplete until we have this tried.
Added subscriber: @CodeManX
Same problem here, Windows 10 Pro 64bit, build 1709 (not fully up to date, Windows Update broken for unknown reasons) and an Nvidia Geforce GTX 970 with latest drivers.
If I remember correctly, 2.78 was initially installed and worked, but that could be months ago. Just updated with the official installer to 2.79b, but still crashes despite the following:
The following build bot builds start without problems however:
Seems highly unlikely that a change to the driver settings would make the official 2.79b work that otherwise crashes, whereas above builds start up just fine without a change to the driver settings.
I can't update Windows at the moment, because something is terrible broken there since 2 weeks. It might have started when I tried to install the Hyper-V feature, which is currently enabled.
Running the crashing 2.79b with -d option:
Doing the same with one of the working builds:
The last line seems relevant. OpenCL crashed apparently, but Blender doesn't seem to care. Is it possible that the older official version doesn't catch this error and crashes?
Added subscriber: @ubc-ssl
I've got the same problem on 2.79, I've installed VC Redist 2013, updated graphics drivers from AMD, and tried running both as admin, and with the software OpenGL dll. I've also tried running with
--factory-startup
, but this is the first run of the program on a new machine, so there are no existing user settings.Added subscriber: @mont29
If builds from May work well, then we can consider the bug as fixed!
Added subscriber: @3di
This comment was removed by @3di
Changed status from 'Resolved' to: 'Open'
i'm getting this problem on version: 2.81 (sub 12), branch: master, commit date: 2019-09-23 09:09, hash:
1d1ef2e797
. It happens when i'm using jacques vs code extension to run a script, but only if the script does anything other than a print command, for example if I try the below, blender shuts down immediately with the access violation exception.context.area: VIEW_3D
import bpy
from mathutils import *
D = bpy.data
C = bpy.context
bpy.ops.mesh.primitive_monkey_add(location=(0,0,0))
code works fine from within blender's text editor.
That extension is not maintained by blender, so if it is not crashing in blender, it is not considered a bug, also this seems to be differnt issue than the original report, please dont use old reports for new issues
just spoke to jacques, he says:
There might not be a good solution for this currently. The issue is, that this uses timers in Blender, which run without a context. (and most operators need a context)
