The bridge tool fails in a situation with multiple rows of faces facing each other #54996
10 Participants
Reference: blender/blender#54996
Win10 Pro 64 bit; AMD Ryzen 2700X; Nvidia GTX 1060 6GB; 32 gigs RAM
Broken: hash
d1be30f
(buildbot build May 4).Worked: never
In a situation where you have multiple rows of faces that face each other across empty space (with other areas where they face away from each other). The bridge tool (even withloop pairs checked) is unable to give priority to the direction the normals are facing. The result of this is that instead of getting nice bridges among the multiple rows of cubes, the tool produces faces that overlap and have zero area. As hinted, theloop pairs checkbox in this case does not do anything and the result is the same.
Open the .blend, invoke the bridge operator (the result is the same whether or not "loop pairs" is selected.
blend
IffyBridge.blend
IffyBridge.blend (updated blend)
An additional note; I submitted this issue years ago, but it was never fixed and I couldn't find my old report. If the bug is not going to be fixed, then just close this as a todo item or with a "won't fix" tag.
Added subscriber: @Ace_Dragon
Added subscriber: @LukasZiechmann
Hi @Ace_Dragon,
I can reproduce this behavior using the operator in the Edge-Special menu. Although checking 'loop pairs'-option does yield a slightly different result than the other options, it can't really be considered the desired result.
If that is a feature you urgently need however, you can already use the add-on "loop-tools" that ships with blender. This produces the expected result.
Added subscribers: @ideasman42, @lichtwerk
#54597 is somewhat related, I will revisit this shortly and see if I can nail this.
Note as in #54597 the situation improves if individual components are moved/rotated just slightly out of the aligned setup [which of course is not a solution at all...]
Like I said, I'll give it a go, if that doesnt succeed, I'll have to ask @ideasman42 to take over...
I'm not sure about the blend file in this report, but found a case where loop-pairs fails in a more obvious way (where the pairs aren't calculated in a consistent way), posted updated blend.
Added subscriber: @Rigoletto
I periodicaly got wrong results too, added screenshot and blend file. I guess its the same probllem.bridge_edge_loop_bug.blend
The bridge tool in this situation is still broken in 2.82 alpha.
If there is no interest in fixing the bug, then one might as well close the report as "won't fix" :-/
Added subscriber: @dr.sybren
The fact that that didn't happen could tell you something ;-)
This is the result I get with 2.82 alpha @
5dc1183580
with the original attached blend file.I'm assuming the report is about the circled faces, but I'm not entirely sure. The report mentions zero area faces, and the ones I circled are merely overlapping.
Increasing the number of cuts does show that there is some twisting going on:
This does looks like a real bug to me, and not just a limitation of the current design.
The bug is that the cubes in the center shouldn't have faces overlapping them at all. There's supposed to be four different bridges that are made with no overlaps (when the selected mode is "loop pairs"). This is what I mean when I say the design does not take the normal direction into account when finding the nearest face(s) to pair with.
Meanwhile, the bridge operator that comes with the Looptools addon (which is bundled with Blender) tackles this case perfectly. There is no reason to not just copy what it does when the loop pairs mode is selected.
The correct result (from Looptools).
Added subscriber: @TheCharacterhero-4
I will not add a countdown until the topic is open.
If this is relevant, then I described in more detail on the forum: https://devtalk.blender.org/t/blender-bridge-edit-loops/14347
Added subscriber: @APEC
Added subscriber: @Zeirus
Added subscriber: @MeshVoid
This is still a thing in 2.91 alpha.
Is there a reason why the face normals cannot be taken into account when bridging pairs, I would think the Bmesh system supports such a thing?
Marking this report a todo, papercut.
Currently the bridge tool only sees edge-loops, it isn't aware of surrounding geometry and how it would best be integrated into the bridge result.
While it can be supported, it's not a mistake in the implementation.
The results can be changed if i rotate one or more edges with "Rotate Edge CW / CCW" (changing index of the edges),
then the direction of the bridge changes sometimes.
But i cant find a pattern to get predicted results. It seem not to belong if the index are ordered CW /CCW.
It cant be random, so maybe if the edge index are considered the should be a solution for a switch to change the direction!?
