Tool shelf options don't cause re-execution sometimes (regression in undo system) #55032
Reference: blender/blender#55032
Linux, Nvidia
Broken: current 2.7 master, revision
d5c1c0b10d
Worked: (optional) master revision
91d0825b55
(on Mar 31, just before Unified Undo commit651b8fb14e
With a certain simple .blend file created with current master, if you try to do a command like bevel and then adjust options on the tool shelf, those adjustments have no effect. It doesn't happen all the time (for instance, doesn't happen on default cube), but will happen with this file that I just created from master @ head. I created it by adding a cone, duplicating it in edit mode and moving the duplicate up some.
pp.blend
Load example file.
Hit control-B, move the cursor some to make a bevel, then lmb click.
On tool shelf, change segments to 2.
Expect: bevel re-executes and creates 2 segments.
What happens: nothing. (using debugger: bevel isn't ever called, so it seems that the operator is not executed)
It isn't just bevel. Another thing to try:
Load example file.
Spacebar search for Intersect (Boolean) and execute that.
On tool shelf, change "Boolean" drop-down to "Union".
Nothing happens.
Added subscriber: @howardt
As a further note, this problem also appears to be in the 2.8 branch (using F6 to bring up tool settings after an initial bevel with control-B, and trying to change segments, on the example pp.blend file).
Tool shelf options don't cause re-execution sometimesto Tool shelf options don't cause re-execution sometimes (regression in undo system)This issue was referenced by
4461be1b72
