Setting duplication group for multiple selected items only affects one item #55034
Closed
opened 2018-05-11 23:46:35 +02:00 by Phil Stopford · 12 comments
Windows 10 Pro, GTX 1060 6 GB
Broken: 2.79b, current 2.79 builds
Alt-left should apply a setting to all selected items (where applicable). This doesn't seem to be the case for the group menu under the duplication setting. Only one of the items gets the change, the others are left untouched.
Create a scene with several empties.
Add Suzanne and place her in a group.
Select all empties and using Alt-Left, change the duplication settings to Group and select the group Suzanne is in, using Alt-left click for the menu actions.
Review the duplication settings for each empty. Only one of the empties will have been changed.
**System Information** Windows 10 Pro, GTX 1060 6 GB **Blender Version** Broken: 2.79b, current 2.79 builds Worked: (optional) **Short description of error** Alt-left should apply a setting to all selected items (where applicable). This doesn't seem to be the case for the group menu under the duplication setting. Only one of the items gets the change, the others are left untouched. **Exact steps for others to reproduce the error** Create a scene with several empties. Add Suzanne and place her in a group. Select all empties and using Alt-Left, change the duplication settings to Group and select the group Suzanne is in, using Alt-left click for the menu actions. Review the duplication settings for each empty. Only one of the empties will have been changed.
Author
Added subscriber: @phil.stopford
Added subscriber: @LukasZiechmann
I can reproduce this behavior here. Trying to set the group for all empties from within the object properties panel doesn't work via Alt-LMB. It works by pressing RMB+'copy to selected'-operator though. So even if this does not work via Alt-LMB, there is a really simple workaround, so that I guess it is not a bug of very high priority, but I let others decide this.
Member
Added subscriber: @lichtwerk
Philipp Oeser self-assigned this 2018-05-14 08:59:53 +02:00
Member
I'll see if I can track this down...
Member
Added subscriber: @ideasman42
Member
UI editing multiple selected items was added in dfbb876d46, bit more info reg. limitations in 2821da5b70
atm. doesnt work for:
  • any object pointer picking (PROP_POINTER)
  • add modifier, add vertex group, etc. so just properties, no operators afaics
  • object color (see comment "/* for now don't support whole colors */")
  • motion path type,...
  • probably others
Anyways, following code here [and limiting to the reported case of PROP_POINTER failing], one can see:
ui_selectcontext_begin() is a success, sets uiSelectContextElem->ptr correctly
ui_selectcontext_apply() doesnt have a switch case for PROP_POINTER, it's just not implemented.
Maybe this was left out intentionally, however D3373 seems to work, maybe @ideasman42 can comment?
UI editing multiple selected items was added in dfbb876d46, bit more info reg. limitations in 2821da5b70 atm. doesnt work for: - any object pointer picking (`PROP_POINTER`) - add modifier, add vertex group, etc. so just properties, no operators afaics - object color (see comment "/* for now don't support whole colors */") - motion path type,... - probably others Anyways, following code here [and limiting to the reported case of `PROP_POINTER` failing], one can see: `ui_selectcontext_begin()` is a success, sets uiSelectContextElem->ptr correctly `ui_selectcontext_apply()` doesnt have a switch case for `PROP_POINTER`, it's just not implemented. Maybe this was left out intentionally, however [D3373](https://archive.blender.org/developer/D3373) seems to work, maybe @ideasman42 can comment?
This issue was referenced by 1318660b04
This issue was referenced by 1318660b0449b6e6afe6d349826af89005bc29dd
Member
Author
Is this supposed to be resolved in the 2.79 code? I'm still seeing this behavior in the current nightly builds, so wanted to check
Member
Yes, this is supposed to be working (and it does for me)
Checked my local master build and todays buildbot build (linux).
Created 3 empties, added Suzanne, Ctr+G, selected all three empties, Alt+click Group type in object duplication, Alt+Click on group selector and choose "Group" --> works here.
Can you confirm this isnt working on your side?
Yes, this is supposed to be working (and it does for me) Checked my local master build and todays buildbot build (linux). Created 3 empties, added Suzanne, Ctr+G, selected all three empties, Alt+click `Group` type in object duplication, Alt+Click on group selector and choose "Group" --> works here. Can you confirm this isnt working on your side?
Author
Ah, that works. There's a different issue (multi-selection of objects, and 'add to group'). I'll file a separate ticket for this - I guess it's not related to this specific case.
Reference: blender/blender#55034
