Undo crash in UV/Image Editor when using linked image
Linux Ubuntu 17.10
Nvidia Quadro GP100
Broken: Blender 2.79 4461be1b722
When a linked image from another file is applied to a mesh in UV/Image Editor and when editing the UVs and using undo, Blender crashes.
Select the sphere and switch to edit mode. Select parts of the UVs, move them & then hit Ctrl + Z. Blender should then crash and close.
Blend. file
Philipp Oeser (lichtwerk) triaged this task as Confirmed, Medium priority.May 16 2018, 1:53 PM
Can confirm this.
MeshUndoStep->id_map->refs->ptr is NULL in this case
1  BKE_undosys_ID_map_lookup            undo_system.c     813  0x276f3e9
2  BKE_undosys_ID_map_lookup_with_prev  undo_system.c     834  0x276f54b
3  mesh_undosys_step_decode_restore_ids editmesh_undo.c   737  0x1c6af1f
4  mesh_undosys_step_decode             editmesh_undo.c   771  0x1c6b10c
5  undosys_step_decode                  undo_system.c     174  0x276d14f
6  BKE_undosys_step_undo_with_data_ex   undo_system.c     529  0x276e656
7  BKE_undosys_step_undo_with_data      undo_system.c     544  0x276e78a
8  BKE_undosys_step_undo                undo_system.c     549  0x276e7b7
9  BKE_undosys_step_undo_compat_only    undo_system.c     626  0x276ed1a
10 ed_undo_step                         ed_undo.c         129  0x186d730
11 ed_undo_exec                         ed_undo.c         222  0x186d98d
