Two ways of creating the same scene result in different values for the objects transforms. #55103
2 Participants
Reference: blender/blender#55103
Void Linux, Nvidia Titan
Also tested on Windows.
2.79b
The following two ways of creating the (seemingly) same scene result in different values for the objects transforms.
Init:
In my description I will call those cube a, cube b, and cube c.
steps towards what I consider the bugged result bugged.blend:
this results in these transform values for the respective cubes:
cube a:
x: 0
y: 0
z: 0
cube b:
x: 0
y: 2
z: 2
cube c:
x: 0
y: 4
z: 0
which is completely puzzling.
In which coordinate system is the transform of cube c supposed to be?
It's not in a global coordinate system, although one could expect it from y being 4.
But z is 0, while one can see by its actual position that in global coordinates it should be 2 (just like its parent b)
It is not in coordinates relative to its parent either, since then y should be 2, not 4.
This makes no sense at all, and I consider it buggy.
Even worse is that you can create the same scene in a different way with the result being exactly what I expect.
Just reorder the operations.
steps towards expected result expected.blend:
cube a:
x: 0
y: 0
z: 0
cube b:
x: 0
y: 2
z: 2
cube c:
x: 0
y: 2
z: 0
Which is what I would expect.
The transforms are relative to their parent.
How could I know from an exported file ( for example I use gltf ), where the nodes are supposed to be positioned?
It's impossible as long as the first way results in nonsensical values for the transform (which get exported 1-to-1 into the gltf file)
The way I think it should be (and how it is in game engines and the like) is that every node should have global and local (meaning relative to its parent) transforms exposed.
It would be simple and require no magical numbers.
Added subscriber: @KevinMichalev
Actually, after some testing, it seems like exporting to gltf does seem to export the transforms relative to their parent.
So everything is fine in that regard.
Still it seems to be confusing for the values in blender to be different just by reordering the actions a bit.
Added subscriber: @lichtwerk
This is because of whats called the
Parent Inverse
.This might not be how this is done in many other applications (but it does its job)
There is some explanation to it in the manual .
Please also refer there to set parenting up without
Parent Inverse
(or how to clear it later)This document also explains it nicely, and there is probably more information on the internet.
So as you say it's not in global coords, it's not in parent's coords either, it's
Note that to my knowledge there is no builtin method to clear it without affecting a childs global transform, but you can do it with a script:
https://blender.stackexchange.com/questions/28896/how-to-clear-parent-inverse-without-actually-moving-the-object
Hope this clarifies it? Dont think this can be considered a bug though...
