Error in UV editor in blender 2.79
Blender 2.79.4
if i activate checkbox tiles my texture does not coincide with the scan.
This is a mistake so it should not be in my opinion.
Is it possible to make a normal counter for the number of repetitions at 2.79 or 2.8?
Vyacheslav (Ghostil) added a comment.EditedMay 19 2018, 8:59 PM
{F3396224}if Tiles x or y set example 2 repaint set 2.
Default repaint set tinfinitely
Tiles
The number of times the texture image is repeated, counting outward in eight directions (the four corners and the four sides).
With Tiles=1, the result is a 3 x 3 grid. With Tiles=2, the result is a 5 x 5 grid, and so on.
You can toggle the tiling feature with the Tile Bitmap checkbox, described below.
This set repaint in 3ds max.
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.
Having a hard time reproducing this.
Mind sharing your .blend file with packed textures so I can have a look?
Marking as incomplete for the time being...
I add my texture and my blend file.
Я хочу возможность задавать количество повторов изображения как это можно делать в 3д макс или Гудини или Мая.Сейчас повторы могут быть только бесконечные или вообще без повторов. Если это накладно сделать в билд для 2.79 возможно это добавить в 2.8?
I want to be able to set the number of times an image is repeated as it can be done in 3D max or Houdini or Maya. Now the repeats can only be infinite or without repeats at all. If it's expensive to do this in build for 2.79, is it possible to add it to 2.8?
This Screen in Houdini set Tailing
Philipp Oeser (lichtwerk) raised the priority of this task from Needs Information from User to Needs Triage by Developer.Jun 20 2018, 3:59 PM
Thanks for the suggestion, but we do not accept feature requests or suggestions on this tracker (use forums or bf-funboard ML for that).
Also, BGE (and all related things, like textured faces) has been removed from blender2.8, so this is no more maintained area of code. Thanks for the report anyway.
OK. I'm waiting for 2.8 there it will be more convenient to work than now. I hope to get a beta 2.8 uv editor there will normally work.
