Hair is dynamic even it is disabled
W10 64b
92f3658
When you add some Field, hair is dynamic even Hair Dynamic is disabled.
  1. Open
  2. Play
  3. All hairs are affected by Wind
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Unknown Status.May 25 2018, 9:24 AM
Hair will react to forcefields [even if Hair Dynamics are disabled].
These are different things, Hair Dynamics just affect the way physics are actually simulated on the hair.
To get rid of the forcefield affecting the hair completely [even for non dynamic hair], you can set the field weight to zero:
Dont think there is a bug here
I never notice that hair is affected by forcefield :) I turned OFF forcefield by your suggestion and I get expected behaviour. Anyway it is great for make turbulence etc without dynamic hair.
One thing else, if you set "Noise" parameter, hair will fast jump during Play animation. It is little bit strange. I would expect static noised hair or fluently animated noise.
But as you mentioned, it is not bug.
