Cycles misses intersections when objects are too close
Open, NormalPublic
macOS 10.13.4
Broken: 2.79b
When two objects are too close, Cycles can miss intersections.
Open the attached .blend file and render.
There are two intersecting semitransparent planes in this file. Their transparencies are set so that any ray passing through both planes gets uniform attenuation. A ray that passes only one plane gets either a green or magenta tint.
Note how the line where the planes intersect has a coloured border.
The source of the problem is the use of ray_offset() to prevent self-intersections for rays that originate from a transparent surface. A solution to this problem is outlined in the paper "Robust Iterative Find-Next-Hit Ray Traversal": http://www.sci.utah.edu/~wald/Publications/2018/nexthit-pgv18.pdf
Philipp Oeser (lichtwerk) triaged this task as Normal priority.Jun 5 2018, 12:47 PM
