Sculpt Dyntopo undo crash #55336
Content
Web Development
7 Participants
Reference: studio/blender-studio#55336
Broken: 2.8 2891fb645b9
When using undo after sculpting with any brush with dyntopo turned on, Blender crashes.
Added subscriber: @JulienKaspar
blender/blender#58102 was marked as duplicate of this issue
Added subscriber: @klowner
I was digging into this a little today but couldn't quite determine how to fix the issue.
Here's an address-sanitizer dump of the crash:
https://gist.github.com/Klowner/dcb1155008452762be26e698d09cbbba
It looks like
sculpt_pbvh_clear()
frees the Object'sob->sculpt->pbvh
, but then then thedraw_manager_*
stuff still has a pointer to the freedpbvh
and attempts to read from it.The problem here is internally there are two undo timelines of undo history that get out of sync.
I've committed a fix for the common case that fails: - simple double free, and missing cow update: blender/blender@6242940639, blender/blender@d9d3e7778c.
However issues remain:
BLI_assert(!"Cannot drop BMLogEntry from middle");
.So I'd like to keep this open since the way undo and sculpt mode bmesh log should be made to work more reliably.
Added subscriber: @Pik-1
I can confirm the bug. It happens systematically to me when following these steps:
Last tested revision: blender/blender@1d4ad68198
Stacktrace and error:
System information:
Added subscribers: @eoinoneill, @lichtwerk
Did a completely clean build today (rebuilt the dependencies and everything), the issue seems to be gone.
Revision blender/blender@11f2c65128
Added subscriber: @jeacom
Hey, I wanna make a patch and submit for review but this problem is happening when I try to build blender for debugging.
I wanna make some changes to sculpt.c, should I just ignore or it can cause problems?
This issue was referenced by blender/blender@f87b93a567
This issue was referenced by blender/blender@06d1c2f737
