Sun light use wrong data rotation in render Cycles
Windows 10 x64
Processor: AMD A10-9600P RADEON R5, 10 COMPUTE CORES 4C + 6G 2.40GHz x64
Graphics Cards: AMD R5 RADEON (For main display), AMD R8 M445DX
RAM: 8GB
Broken: 2.79b
Project
The Sun light type, is not taking the appropriated rotation and when i render the scene the light is targeting almost in inverse orientation of what a specified in the rotation of the object in Cycles engine.
Add a sun light object in the scene.
Add a box in the scene.
Add a camera in the scene.
Target the box with the camera object.
Choose a direction for the sun light object by rotating it.
Press render.
The Sun light should render the light somewhat in a different rotation than specified, especially in the Z rotation. It also cause problems on the XY rotation and does an inverse rotation when they go to negative values.
Try setting the lamp size to 0 or a small number, in this .blend it is set to cover a big part of the hemisphere. We have a to do item to clarify this by changing the sun size to display as an angle.
Also note using a light falloff node for a sun lamp is not very meaningful, as the sun is considered to be infinitely far away.
