Typo in "blender --debug-cycles" Output When CUDA Unavailable
Broken: Blender 2.79
The word "was" is mistyped as "wad" in the sentence "Neither precompiled kernels nor CUDA compiler wad found, unable to use CUDA", visible when running blender --debug-cycles.
  1. Uninstall CUDA
  2. Run blender --debug-cycles
Observed behavior:
I0611 23:08:13.094699 26748 blender_python.cpp:186] Debug flags initialized to:
CPU flags:
  AVX2   : True
  AVX    : True
  SSE4.1 : True
  SSE3   : True
  SSE2   : True
  QBVH   : True
  Split  : False
CUDA flags:
 Adaptive Compile: False
OpenCL flags:
  Device type    : ALL
  Kernel type    : DEFAULT
  Debug          : False
  Single program : True
  Memory limit   : 0
I0611 23:08:13.127159 26748 device_opencl.cpp:63] CLEW initialization failed: Error opening the library
I0611 23:08:13.128432 26748 device_cuda.cpp:2096] CUEW initialization succeeded
I0611 23:08:13.132863 26748 device_cuda.cpp:2107] Neither precompiled kernels nor CUDA compiler wad found, unable to use CUDA
Eexpected behavior:
CPU flags:
  AVX2   : True
  AVX    : True
  SSE4.1 : True
  SSE3   : True
  SSE2   : True
  QBVH   : True
  Split  : False
CUDA flags:
OpenCL flags:
  Device type    : ALL
  Debug          : False
  Memory limit   : 0
I0611 23:08:13.132863 26748 device_cuda.cpp:2107] Neither precompiled kernels nor CUDA compiler was found, unable to use CUDA
