[Vertex Group] "Delete all unlocked groups" not working #55461
5 Participants
Reference: blender/blender#55461
Win10
Broken: 2.79b f4dc9f
I locked 2 groups, I clicked "Delete all unlocked groups" in the menu.
However, all groups are cleared, both locked and unlocked.
Update:
I found that its not working only after working a while on Blender, like assigning and removing vertices from groups, switch edit mode on/off etc.
If it's not working, the following steps can make it work again for a while, for unknown reasons...
Added subscriber: @wonson
Added subscriber: @lichtwerk
Seems I cannot reproduce this (I know you've mentioned it only happens after a while of working, but I did quite a bit of assigning/removing, obmode/editmode switching to no avail...)
The fact that this wont happen in a saved/reopened file apparently makes it even harder to reproduce.
Could you find the steps that actually lead to this behavior?
(Giving us the log of the Info-Editor [where operators and property changes are recorded] might also help...)
Marking as incomplete for the time being...
OK, trying.
Just found out that saved/reopened only fix it for a while, the "Delete all unlocked groups" will eventually be broken again at some point.
The real trigger is still unknown though.
Added subscriber: @mont29
I’m sorry, but we cannot investigate an issue we cannot reproduce, so will archive this report until someone can give enough elements to consistently reproduce it. Thanks for the report anyway.
Sorry for that, I can't find the rule of it.
One thing I suspect is: The mesh having the problem is an imported fbx made by 3dsmax, with vertex groups.
Added subscriber: @fangscomic
I had the same problem yesterday, then i found this post.
So i test it on 3 objects, each object have some vertex group.
Object 1, I locked some of it and click "delete all groups" (maybe this action is where the bug starts)I go object 2, locked some vertex group, clickDelete all unlocked groups ... result was all deleted
Then I redo action (Ctrl + Z) on object 2,
delete any unlocked vertex group by clicking on minus sign, after that I perform Delete all unlocked groups... It works or even after that.
I test on object 3, locked some vertex group, click Delete all unlocked groups , it does not give any problem.
The Delete all unlocked groups button is alive!
It seem the "delete all groups"button still have someinfluence once after you click it...
I hope this could help the developer to figure it how this error happen.
Ah thanks, now I see what happens here, fix incoming.
This issue was referenced by
42ba294235
