Master GPU Cuda render tile at full screen res crash's blender or gives Cuda sync error
Win 10, Nvidia 750ti 2gb, Latest drivers, i5 12GB ram
Master
Works in 2,79b
Set render tile size for GPU rendering with cuda to full screen res e.g 1920x1080, builds BVH etc OK ,starts to render but either Blender crash's or sometimes your get a cuda sync error message
Same as above
Any chance you can check your event log for any TDR related events around the time of the crash?
It wasn't a time out issue, Blender would just stop operating and windows message would pop up saying blender had crashed and needed to close. Ill try to get some debug info later, some times it list a cuda line number with the error if doesn't just hard crash blender.
I tried the Benchmark scene with the sheep, and got the following rather than a hard crash this time:
I0616 16:16:50.098348 8188 device_cuda.cpp:850] Buffer allocate: work_tiles, 40 bytes. (40) in device memory
CUDA error: Unknown error in cuCtxSynchronize(), line 1712
Refer to the Cycles GPU rendering documentation for possible solutions:
https://docs.blender.org/manual/en/dev/render/cycles/gpu_rendering.html
CUDA error: Unknown error in cuMemcpyDtoH((uchar*)mem.host_pointer + offset, (CUdeviceptr)(mem.device_pointer + offset), size), line 961
If I drop the render res to 720z420 as single tile render it renders but at 100% when should denoise it gives another error:
CUDA error: Launch failed in cuMemcpyDtoH((uchar*)mem.host_pointer + offset, (CUdeviceptr)(mem.device_pointer + offset), size), line 961
Error: CUDA error: Launch failed in cuCtxSynchronize(), line 1390
Brecht Van Lommel (brecht) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.EditedJul 13 2018, 1:47 PM
If the render crashes in a simple file with 1920x1080 tiles, please attach the .blend.
For the victor/sheep benchmark, it may still be running out of memory even if the error is unclear. There will be 12GB - 4GB = 8GB host memory available, which is potentially not enough to render this file. Especially with such large tile size, which should not be needed anymore, just use a small tile size like 64x64.
The most important thing for us to debug this is to attach the full log from running Blender with --debug-cycles and the resulting crash. If you make any changes to the file we also need to know, since for example the standard victor.blend does not have denoising enabled.
Bastien Montagne (mont29) closed this task as Archived.Jul 25 2018, 9:36 PM
