Blender freezes on startup #55520
Reference: blender/blender#55520
OS: Windows 10 build 1803
GPU: Radeon RX 480
Broken: 2.78b and newer
Worked: 2.78a and older
Blender freezes after the command line opens and the grey Blender window showed up, but before everything else.
Opens Blender directly or via command line
Blender frozen (non-responsive), showing only grey inside the Blender window. (As attached screenshot)
Extra info
I've also ran various command line arguments, note that all these commands showed only output with 2.79b, but similar results were met when using with any version from 2.78b and above.
R:\Program Files\Blender Foundation\Blender>blender
AL lib: (EE) UpdateDeviceParams: Failed to set 44100hz, got 96000hz instead
found bundled python: R:\Program Files\Blender Foundation\Blender\2.79\python
R:\Program Files\Blender Foundation\Blender>blender --verbose 9 -noaudio --debug-value 9 -con -Y -d --debug-gpu -noglsl -nojoystick
Switching to fully guarded memory allocator.
Blender 2.79 (sub 0)
Build: Thu 03/22/2018 09:59 AM Windows
argv- [x] = blender
argv- [x] = --verbose
argv- [x] = 9
argv- [x] = -noaudio
argv- [x] = --debug-value
argv- [x] = 9
argv- [x] = -con
argv- [x] = -Y
argv- [x] = -d
argv- [x] = --debug-gpu
argv[10] = -noglsl
argv[11] = -nojoystick
disabling nojoystick
read file
Version 272 sub 2 date unknown hash unknown
ordered
OBCube
OBLamp
OBCamera
Using OpenGL 4.3 debug facilities
GL application marker: Successfully hooked OpenGL debug callback.
GL_CONTEXT_PROFILE_MASK = 0x2 (compatibility profile)
R:\Program Files\Blender Foundation\Blender>blender -E BLENDER_RENDER/BLENDER_GAME/CYCLES
Added subscriber: @Strawberrysmoothies
Added subscriber: @lichtwerk
Total shot in the dark, but:
--factory-startup
?Marking as incomplete until we have an answer on these two questions...
Hi,
Thank you for the reply!
Beside Windows Defender, I only have Malwarebytes installed, disabling it still gives the same result.
When using --factory-startup, the same issue persist with this same output:
found bundled python: C:\Program Files\Blender Foundation\Blender\2.79\python
Could you try a new build from https://builder.blender.org/download?
If that still doesnt work, could you try dropping this dll in the folder where blender.exe resides and test again? (you can remove it after the test)
I've tried the latest 2.79 and 2.80 builds (both with and without New Compiler), the results are still the same.
When retesting using the provided opengl32.dll, 2.79 builds and 2.80 builds behaved differently.
On 2.79 builds, the same thing occurred, but the output from the console is slightly different:
Warning! Legacy WGL is unable to select between OpenGL versions.found bundled python: C:\Program Files\Blender Foundation\Blender\2.79\python
On 2.80 builds, an error dialogue appeared saying "Blender requires a graphics driver with at least OpenGL 3.3 support" and Blender didn't start, the console has the following output:
Win32 Error# (0): The operation completed successfully.
I hope that helped!
Added subscriber: @mont29
Yes, 2.8 won’t run with old software OpenGL am afraid…
The issue must be related to either your hardware, or your OS/driver though, pretty much impossible to help further without being able to investigate ourselves, so will archive the report for now.
