BAT doesn't pack smoke cache
Attached is a .blend file. If you bake the smoke cache and pack it with BAT, it won't pack the smoke cache files.
This is related to: T55007
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.
Yep, smoke is not implemented (yet), rBASTdfa07e19cc35 just did it for fluids...
So cdef eModifierType_Smokesim = 31 and corresponding modifier_walker is still missing.
I could have a go at it (just started fiddeling with BAT and P732 is a start -- but needs further love [just pointcache, no OpenVDB, ...] -- also this suffers from the same glob vs. pathlib.Path.exists() issue as in T55007, T55539)
But before I continue, I would like to ask @Sybren A. Stüvel (sybren) if this is better placed on his desk?
Also this is probably not a bug, but a known limitation and more of a TODO?
My plate is already pretty full with Code Quest stuff, so I appreciate your help. P732 seems like a good first step. Once you're a bit further, in a diffusion patch and I can give you some more feedback. For now I've commented on P732.
oki, will see what I can do...
