Cycles CUDA error Launch failed cuCtxSynchronize results in Blender stuck in
Open, NormalPublic
Hey guys,
sry if I made any mistakes or any info you need is missing but I'm very new in this forum and need your help ... I've been googling and searching all over the place but couldn't find anything regarding my error.
I've a scene in Blender which should not be a big deal to render out through Cycles Render. But as soon as I start rendering (via Shift+Z or F12) it throws me the error:
CUDA error: Launch failed in cuCtxSynchronize(), line 1372
and after that it just gives me the error:
CUDA error at cuCtxCreate: Launch failed
I tried messing with my tile size, nothing worked. Changed the Path Tracing/ Branched Path Tracing settings...
But I noticed it renders just fine as soon as I use my CPU to render. Although that is extremely slow and not a real alternative to me ...
The Console Output looks like this:
Read prefs: C:\Users\juliu\AppData\Roaming\Blender Foundation\Blender\2.79\config\userpref.blend
AL lib: (EE) UpdateDeviceParams: Failed to set 48000hz, got 44100hz instead
found bundled python: X:\Programme\Steam\steamapps\common\Blender\2.79\python
Read blend: Y:\Uni\Digitale Medien\VideoPraktikum\BlenderProjects\HumanEnemyBackground.blend
Refer to the Cycles GPU rendering documentation for possible solutions:
https://docs.blender.org/manual/en/dev/render/cycles/gpu_rendering.html
CUDA error: Launch failed in cuCtxSynchronize(), line 1835
CUDA error: Launch failed in cuMemFree(cuda_device_ptr(mem.device_pointer)), line 615
CUDA error: Launch failed in cuGraphicsUnregisterResource(pmem.cuPBOresource), line 1616
CUDA error: Invalid context in cuMemAlloc(&device_pointer, size), line 568
CUDA error: Invalid value in cuCtxDestroy(cuContext), line 279
I use a GeForce GTX 1080 Ti with 11 GB of VRAM so VRAM shouldn't be an issue. And I'm also not running any other VRAM heavy applications in the background ...
Any help is appreciated.
Have a great day!
electric
Apparently it has to do with my smoke simulations ... I don't know what though ...
I have exactly the same problem but im not running smoke simulations. seems to have something to do with volumetrics.
im running a gtx 1070 8gb the whole scene runs fine until i start using volume absorption connected to the volume on material output node.
