Wrong object selection with multiple view layers #55617
8 Participants
Reference: blender/blender#55617
Kubuntu 17.10, AMD Tonga PRO Radeon R9 285/380 video card with Mesa drivers
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tonga PRO [Radeon R9 285/380]
Broken:
476b4c415c
Right-click to select sometimes selects the wrong object. Multiple clicks will cycle to the correct object eventually.
Switching the view layers is important; without it, the bug doesn't show up.
recording-2018-06-25_15.35.30.mp4
#62666 was marked as duplicate of this issue
Added subscriber: @dr.sybren
The problem in the video looks a bit similar to #62666.
Added subscribers: @MACHIN3, @RobertWesseling, @Teds
Right-click selects the wrong objectto Wrong object selection with multiple view layersAdded subscriber: @brecht
DepsgraphNodeBuilder::build_view_layer
assigns each originalObject
a uniqueselect_id
, based on its order in the view layer base list. If there are multiple view layers this can't work correctly, as objects are shared between view layers.context.scene.update()
updates all view layers in the scene, instead of just the active one as usual, so that's another way to trigger the problem.Possible solutions:
a)
select_id
inBase
which is per view layer.b)
select_id
in each originalObject
, based on its position in themain->objects
list.c)
select_id
in each evaluatedObject
which is per view layer.d) Build a temporary hash for selection and don't store it persistently at all.
Removed subscriber: @Teds
Added subscriber: @RainerTrummer
Added subscriber: @dfelinto
Added subscriber: @ideasman42
Evaluating the different options @brecht proposes
a) no change in performance as it is a counter, when selecting the base needs to be checked. which I assume would be no problem, impacts a lot of code as select_id is used in many places
b) smallest change in code, adds loop over all objects in
(negligible performance impact), but does update objects that are not needed at this moment. You could argue if it is logical to add the code to the build_view_layer....c) not 100% sure about c, but that could also be my limmitted knowledge of the depsgraph evaluation. isn't the orig object used when no changes happens to the object?
d) you could argue that this option is the best in design as it solves the issue in the selection code and does not use deps builder at all, but will impact a lot of code as select_id is used in many places and for all these placed we need to find a solution.
Looking at the time we might want to spend on this issue I would go for B in the short term.
Hmmm... armature drawing, meta balls use the select_id on object.
Just discussed for the next solution:
