Boolean - Animation - Viewport works correctly render view doesnt #55672
Open
opened 2018-06-29 05:56:08 +02:00 by Carlo Andreacchio · 20 comments
Ubuntu 18.04, Win 7 x64
Broken: d53093953f
Booleans dont match between Viewport and Render
  1. Open attached blend file
  2. Preview render (shift z)
  3. Notice the green on top
  4. F12 Render
  5. Notice how the green is no longer there
booleansBug.blend
**System Information** Ubuntu 18.04, Win 7 x64 **Blender Version** Broken: d53093953f8 **Short description of error** Booleans dont match between Viewport and Render **Exact steps for others to reproduce the error** 1. Open attached blend file 2. Preview render (shift z) 3. Notice the green on top 4. F12 Render 5. Notice how the green is no longer there [booleansBug.blend](https://archive.blender.org/developer/F3824329/booleansBug.blend)
Added subscriber: @candreacchio
Seems like it has something to do with the animation on the Boolean. Clearing the animation makes the boolean work correctly.
Member
Added subscriber: @lichtwerk
Member
It has to do with cycles motion blur, 2.79b seems to render fine.
Disabeling motion blur or setting it to Center on Frame seems to render the boolean OK.
It has to do with cycles motion blur, 2.79b seems to render fine. Disabeling motion blur or setting it to `Center on Frame` seems to render the boolean OK.
Member
Added subscriber: @brecht
Member
Sorry about the regression tag, 2.79b with bmesh boolean was also bad...
So, seems to be limitation with bmesh booleans not supporting cycles motion blur in certain scenarios... (e..g. frame 462 in example file is bad, 461 is good, 463 also is...)
Confirming, digging deeper later... maybe @brecht knows right away?
Sorry about the regression tag, 2.79b with bmesh boolean was also bad... So, seems to be limitation with bmesh booleans not supporting cycles motion blur in certain scenarios... (e..g. frame 462 in example file is bad, 461 is good, 463 also is...) Confirming, digging deeper later... maybe @brecht knows right away?
Brecht Van Lommel self-assigned this 2018-06-29 14:05:53 +02:00
It's a documented limitation, animated booleans don't work well with motion blur.
https://docs.blender.org/manual/en/dev/render/cycles/settings/scene/render/motion_blur.html
The only solution for now is to disable motion blur for such objects.
It's a documented limitation, animated booleans don't work well with motion blur. https://docs.blender.org/manual/en/dev/render/cycles/settings/scene/render/motion_blur.html The only solution for now is to disable motion blur for such objects.
@brecht disabling the motion blur for both objects does not fix the issue. I have reuploaded the file, with both objects having disabled motionblur yet the bug persists
booleansBug2.blend
@brecht disabling the motion blur for both objects does not fix the issue. I have reuploaded the file, with both objects having disabled motionblur yet the bug persists [booleansBug2.blend](https://archive.blender.org/developer/F3831629/booleansBug2.blend)
Added subscriber: @mont29
Can confirm that even though mblur is disabled for both operand objects, result in render is wrong. You have to disable mblur for whole Cycles (in its render settings) to get correct render.
Added subscriber: @Darksunrise
Brecht Van Lommel was unassigned by Dalai Felinto 2019-12-23 16:36:08 +01:00
Added subscriber: @dr.sybren
Sybren A. Stüvel self-assigned this 2020-02-04 16:13:27 +01:00
Given the comments by @brecht and @mont29 above, I'm closing this as a known limitation.
Changed status from 'Archived' to: 'Confirmed'
To me it seems a bug, given that my comment was mistaken.
Sybren A. Stüvel removed their assignment 2020-02-11 17:32:47 +01:00
Member
Member
With the Exact boolean method, the render has the same green area as the viewport render, so maybe we can call this issue resolved?
However, I do get correct results with EEVEE even with the "Fast" boolean method, so this probably points to an issue with Cycles.
With the [Exact ](https://wiki.blender.org/wiki/Reference/Release_Notes/2.91/Modeling#Boolean) boolean method, the render has the same green area as the viewport render, so maybe we can call this issue resolved? However, I do get correct results with EEVEE even with the "Fast" boolean method, so this probably points to an issue with Cycles.
Philipp Oeser removed the
label 2023-02-09 13:58:31 +01:00
7 Participants
Reference: blender/blender#55672
