Non-selected keys in Graph Editor are invisible
Xbuntu / AMD
404bacc
In the Graph Editor, only keys that are selected are visible which means you are effectively having to work blindly.
New File
Animate the cube doing some movements over some timespan
Go to the Graph Editor
Deselect all keys
...you'll only see the curves but none of the keys...
Joshua Leung (aligorith) claimed this task.
Joshua Leung (aligorith) triaged this task as Confirmed, High priority.
I'm guessing that the problem is theme related. Using a slightly older version of the 2.8 default theme (from 1-2 weeks ago), the dots are still visible. What's probably happening is that the point colors are reading the alpha values, which are currently set to 0.
