FBX of multiple actions missing keyframes
Mac OS 10.13.4 (17E202) NVIDIA GeForce GT 750M 2048 MB graphics
FBX Exporter 3.7.13
The scene appears to only export some keyframes after I add multiple actions. An earlier version of the scene only had an animated camera. In the attached scene I've added animated planes and lights. When I export the FBX and import into MayaLT, the camera only has a few frames keyed.
  1. Import attached scene
  2. Using fbx 7, set Simplify to 0
  3. Crean a new Blender scene and import the FBX
  4. Note that some keys are missing
Confirmed the issue is present in 3.9.1 of the FBX exporter.
We do not handle user support on this tracker, only bug reports. User forums like blenderartists.org or blender.stackexchange.com should be used for that matter.
Set Simplify setting of animation options of the exporter to 0.0 to avoid any removal of baked keys from curves (by default, it applies some level of simplification to reduce a bit the size of baked animation curves…)
Hey Bastien,
Sorry I don't understand why you think this isn't a bug, were you able to get the sample scene to export correctly? I have tried setting Simplify to 0 to no effect.
Thanks in advance,
Jesse
Jesse (FreakTheMighty) updated the task description. (Show Details)
I've updated the steps for reproducing the bug to set simplify to 0.
Bastien Montagne (mont29) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Jul 17 2018, 2:21 PM
@Jesse (FreakTheMighty) just tried with your .blend, exporting with simplify set to zero gives me all keyframes (one per frame for the nine loc/rot/trans values) when re-importing FBX file here…
Note that current version of the exporter is 3.9.1, would suggest you try the latest build from our buildbot.
Thanks for trying to reproduce it. As I noted in my second comment I did test on 3.9.1. Strange that its working for you, let me investigate more.
I’m sorry, but we cannot investigate an issue we cannot reproduce, so will archive this report until someone can give enough elements to consistently reproduce it. Thanks for the report anyway.
