Blender 2.79 - New Despgraph - Animation gets out of sync when dealing with visibility.
Linux x64 Ubuntu 17.10
Broken: b85be88655c
  1. Start blender with new despgraph and blank scene. Add a cube
  2. set frame to frame 1
  3. insert keyframe on visibility on both render & viewport via outliner
  4. set frame to frame 10
  5. toggle visibility on both render & viewport via outliner
  6. insert keyframe on visibility on both render and viewport via outliner
  7. set frame to frame 1
  8. insert keyframe on location by hovering over the location in the N toolbar and pressing i
  9. press up arrow to jump to frame 10
  10. click & drag the Z location in the N toolbar to the left to change the location on the z axis, i moved it ~1m
  11. hover over the locations in the n tool bar and press i
  12. click drag in the timeline between frames 1 and 10 and notice how it doesnt move
Would someone be able to confirm this bug please?
Bastien Montagne (mont29) triaged this task as Incomplete priority.Jul 26 2018, 11:16 AM
Please follow our submission template and guidelines, also read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
Also please try with blender2.8 build, that the reference one for new depsgraph. ;)
Carlo Andreacchio (candreacchio) raised the priority of this task from Incomplete to Needs Triage.EditedJul 26 2018, 12:44 PM
EDIT: I tried to make a blend file and though it summarised the problem. seems like I can only provide a blank scene to ensure this bug is seen in a consistant manner. Can you please tell me which of hte steps I listed out are not precise enough? I can provide a blank blender scene if required, but it seems pretty pointless.
In regards to blender 2.8. It is not possible to animate blender2.8 viewport visibility which means I am unable to confirm whether this also effects blender2.8. It would be great to get this fixed in blender 2.79
Bastien Montagne (mont29) closed this task as Archived.Jul 26 2018, 5:01 PM
Welll then… will archive for now. Am sorry, but 2.79 won’t get any new fixes (especially not regarding non-finalized features like new depsgraph), so if this is not reproducible in 2.8 there is no point to keep it open really. Thanks for the report anyway.
