Deleting Node with driver attach causes crash
Windows 10 Pro
Core i5 - 2500K 3.3GHz
Geforce GTX 1060 6GB
16GB Ram
Broken:
2.80 94722121e57 win64 New Compiler
2.80 0fc72070fe6 win64
Worked:
2.79 5bd8ac9
Deleting a node in the shader editor that has a driver attached to one of the values cause blender to crash.
Open Sample Blend file in Blender 2.8
Select and Delete the Emission node that has an attached driver
Blender will crash
Link to Sample Blend file.
(https://www.dropbox.com/s/ecd95z8gcom6baa/Driver%20Node%20Bug.blend?dl=0)
This seems to happen with any node. Video attached showing process.
https://youtu.be/yPJzOrL4bEQ
Bastien Montagne (mont29) triaged this task as Needs Information from User priority.
Please follow our submission template and guidelines, also read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
Updated the task with a blend file.
Bastien Montagne (mont29) raised the priority of this task from Needs Information from User to Confirmed, Medium.
Thanks, can confirm. Crash happens in BKE_animsys_eval_driver() during depsgraph eval, looks like some update/rebuild is missing, @Joshua Leung (aligorith), care to check? Thanks.
Philipp Oeser (lichtwerk) closed this task as Resolved.
This seems resolved for me.
@James M (James20) : please try a new build and report back if issues persist...
