Copy Location Constraint has bug with parent (after rotated).
win10 64bit
Broken: 2.79b
Worked: not sure
After rotating The animation looks bad (wrong direction). Maybe need to multiple parent maxtrix?
Thanks!
Best Regards!
GIF
blend file
Hi! Aligorith! Hope you have time to join this session. Thanks!
Bastien Montagne (mont29) closed this task as Archived.
This is not a valid set-up, it generates some dependency cycles, even in 2.8’s new depsgraph:
'OBCube.001.TRANSFORM_CONSTRAINTS()' depends on 'OBEmpty.TRANSFORM_FINAL()' through 'Copy Location'
'OBEmpty.TRANSFORM_FINAL()' depends on 'OBEmpty.TRANSFORM_OBJECT_UBEREVAL()' through 'Temp Ubereval'
'OBEmpty.TRANSFORM_OBJECT_UBEREVAL()' depends on 'OBEmpty.TRANSFORM_PARENT()' through 'Temp Ubereval'
'OBEmpty.TRANSFORM_PARENT()' depends on 'OBEmpty.TRANSFORM_LOCAL()' through 'ObLocal -> ObParent'
'OBEmpty.TRANSFORM_LOCAL()' depends on 'OBCube.TRANSFORM_FINAL()' through 'Parent'
'OBCube.TRANSFORM_FINAL()' depends on 'OBCube.TRANSFORM_CONSTRAINTS()' through 'ObConstraints -> Done'
'OBCube.TRANSFORM_CONSTRAINTS()' depends on 'OBCube.001.TRANSFORM_FINAL()' through 'Track To'
'OBCube.001.TRANSFORM_FINAL()' depends on 'OBCube.001.TRANSFORM_CONSTRAINTS()' through 'ObConstraints -> Done'
