Blender 2.8 Crashes a lot on segmentation fault 11 (on Macbook Air) #56132
Reference: blender/blender#56132
OSX 10.12.6 Macbook Air, Intel HD 5000
Broken: I'm still compiling several commits to pinpoint where it went wrong.. but I can't remember having these a month ago or so..
On unpredictable (yet) moments blender crashes.
Showed a debug/crash log on IRC and Ton replied: the UI, preview render for icons is crashing, advised to report it..
There is no real fail save why I'm sorry. But this helps:
1.txt
2.txt
Added subscriber: @kostex
Added subscriber: @brita
Could you add exact steps to reproduce a crash?
Does it happen with an empty file and the factory settings?
See running Blender from the command line with factory settings:
Added subscriber: @ArtoKitula
As said on IRC, build with CMAKE_BUILD_TYPE=Debug so we get possible assert also.
Hi Inês,
Would you please be so kind and read my report?
There I have stated that I've started with factory default is the first thing to do to reproduce.
The strange thing is that if I start blender (with fac.default) and (as an example, because there are LOTS of ways to get the crash.. most of them when deleting/adding a world object/material/modifier etc.:
Starting blender right back up and do the same..
it will work!
Maybe because that specific memory address is then initialised from the first startup and by chance/cache using it again (?) long shot...
That would explain the segmentation fault 11 in the first place.. not initialising a variable/allocation
(please examine the log files)
Will do the debug build ASAP
Let's keep this incomplete until debug build crashlog.
Hi Roel,
I have looked at both log files, but they don't have enough information to debug this issue.
Therefore, to reproduce this issue, it would be helpful to get the exact steps with the factory settings (as you had already done) and from a default file (which I am not sure is the case).
I am not sure what you mean by "Enable preview". Is this a material preview in the properties?
Please don't take the "Incomplete" status "your issue won't be fixed", but as "Need more info".
Enable preview:
This is the version I'm using:
debug_version_280.txt
blender_debug_build_log.txt
here are 2 crashlogs.. one with --factory-startup, the other without.. Several combinations/adding/removing.. all lead to crash at some time.. not getting a definite reproducable result..
crash_debug_2.txt
crash_debug_1.txt
And here is a backtrace when runned through lldb
debug_log_lldb.txt
Closed as duplicate of #55475
