Dynamic Paint generated Vertex Influence affects Size of Particle system but nothing else. #56184
2 Participants
Reference: blender/blender#56184
Windows 10,
Broken: Master branch Hash
018c9af446
, also 2.79b doesnt workWorked: no idea.
when using vertex paint to generate influences on a vertex group its all fine, but when applied that vertex group to a particle system it only works in the "length" but not on any of the other particle inputs.
Its a bit long but simple, so im providing a file rignt up to test.
Create an object that will be canvas (plane?)
Subdivide it so you have enough vertices to play with
Go on the dynamics tab, select dynamic paint
Add Canvas
Under Dynamic Paint advanced select surface type: Weight
under Dynamic Paint Output hit the plus sign to create a vertex group (dp_weight is the default, that should be fine.)
go on the second object,,
go in the dynamics tab, select dynamic paint
this time add brush
make an animation (or you can use it interactively in play) of the brush object to go touching the canvas object.
on the canvas object, go to the particles property and add a new particle system
make it be hair
go under the vertex groups tab, and under length pick your vertex group (the only one there is)
if you push play, you should seee the hair grow as the brush object goes throught the canvas object.
it completely stops working while it should
dpdemo.blend
Added subscriber: @LucianoMunoz
Added subscriber: @mont29
Thanks for the report, but that is a known limitation of current particle system, not considered a bug.
Ah darn, why does it work with size and not density? Shouldnt this limitation affect both?
