Blender 2.8 crash on startup, but starts with -d --debug-gpu
Closed, DuplicatePublic
Windows 10 Home 64-bit, GeForce 9600 GS 768MB (NVIDIA driver 342.01)
Broken: 2.80 Hash 0f449541d2e 2018-07-31
Worked: 2.79b (last official), works like a charm, without GPU rendering though (GPU seems to be too old :)
Crash on startup without notification
Starting Blender the system console can be seen briefly, Blender window opens briefly with only grey background and closes without error. When starting with -d --debug-gpu Blender is starting fine, but so slow that it's a slideshow, even when hovering over a button or menu it needs seconds to react. I also changed to OpenGL Render, but no improvement of performance.
Extract from 2.79b System info regarding OpenGL:
renderer:	'GeForce 9600 GS/PCIe/SSE2'
vendor:		'NVIDIA Corporation'
version:	'3.3.0'
extensions:
	GL_ARB_ES2_compatibility
	GL_ARB_ES3_compatibility
	GL_ARB_arrays_of_arrays
	GL_ARB_base_instance
	GL_ARB_blend_func_extended
	GL_ARB_clear_buffer_object
	GL_ARB_color_buffer_float
	GL_ARB_compatibility
	GL_ARB_compressed_texture_pixel_storage
	GL_ARB_conservative_depth
	GL_ARB_copy_buffer
	GL_ARB_copy_image
	GL_ARB_debug_output
	GL_ARB_depth_buffer_float
	GL_ARB_depth_clamp
	GL_ARB_depth_texture
	GL_ARB_draw_buffers
	GL_ARB_draw_elements_base_vertex
	GL_ARB_draw_instanced
	GL_ARB_enhanced_layouts
	GL_ARB_explicit_attrib_location
	GL_ARB_explicit_uniform_location
	GL_ARB_fragment_coord_conventions
	GL_ARB_fragment_layer_viewport
	GL_ARB_fragment_program
	GL_ARB_fragment_program_shadow
	GL_ARB_fragment_shader
	GL_ARB_framebuffer_no_attachments
	GL_ARB_framebuffer_object
	GL_ARB_framebuffer_sRGB
	GL_ARB_geometry_shader4
	GL_ARB_get_program_binary
	GL_ARB_half_float_pixel
	GL_ARB_half_float_vertex
	GL_ARB_imaging
	GL_ARB_instanced_arrays
	GL_ARB_internalformat_query
	GL_ARB_internalformat_query2
	GL_ARB_invalidate_subdata
	GL_ARB_map_buffer_alignment
	GL_ARB_map_buffer_range
	GL_ARB_multi_bind
	GL_ARB_multisample
	GL_ARB_multitexture
	GL_ARB_occlusion_query
	GL_ARB_occlusion_query2
	GL_ARB_pixel_buffer_object
	GL_ARB_point_parameters
	GL_ARB_point_sprite
	GL_ARB_program_interface_query
	GL_ARB_provoking_vertex
	GL_ARB_robust_buffer_access_behavior
	GL_ARB_robustness
	GL_ARB_sampler_objects
	GL_ARB_seamless_cube_map
	GL_ARB_separate_shader_objects
	GL_ARB_shader_bit_encoding
	GL_ARB_shader_objects
	GL_ARB_shader_texture_lod
	GL_ARB_shading_language_100
	GL_ARB_shading_language_420pack
	GL_ARB_shading_language_include
	GL_ARB_shading_language_packing
	GL_ARB_shadow
	GL_ARB_stencil_texturing
	GL_ARB_sync
	GL_ARB_texture_border_clamp
	GL_ARB_texture_buffer_object
	GL_ARB_texture_buffer_range
	GL_ARB_texture_compression
	GL_ARB_texture_compression_rgtc
	GL_ARB_texture_cube_map
	GL_ARB_texture_env_add
	GL_ARB_texture_env_combine
	GL_ARB_texture_env_crossbar
	GL_ARB_texture_env_dot3
	GL_ARB_texture_float
	GL_ARB_texture_mirror_clamp_to_edge
	GL_ARB_texture_mirrored_repeat
	GL_ARB_texture_multisample
	GL_ARB_texture_non_power_of_two
	GL_ARB_texture_query_levels
	GL_ARB_texture_rectangle
	GL_ARB_texture_rg
	GL_ARB_texture_rgb10_a2ui
	GL_ARB_texture_stencil8
	GL_ARB_texture_storage
	GL_ARB_texture_storage_multisample
	GL_ARB_texture_swizzle
	GL_ARB_texture_view
	GL_ARB_timer_query
	GL_ARB_transpose_matrix
	GL_ARB_uniform_buffer_object
	GL_ARB_vertex_array_bgra
	GL_ARB_vertex_array_object
	GL_ARB_vertex_attrib_binding
	GL_ARB_vertex_buffer_object
	GL_ARB_vertex_program
	GL_ARB_vertex_shader
	GL_ARB_vertex_type_10f_11f_11f_rev
	GL_ARB_vertex_type_2_10_10_10_rev
	GL_ARB_viewport_array
	GL_ARB_window_pos
	GL_ATI_draw_buffers
	GL_ATI_texture_float
	GL_ATI_texture_mirror_once
	GL_EXTX_framebuffer_mixed_formats
	GL_EXT_Cg_shader
	GL_EXT_abgr
	GL_EXT_bgra
	GL_EXT_bindable_uniform
	GL_EXT_blend_color
	GL_EXT_blend_equation_separate
	GL_EXT_blend_func_separate
	GL_EXT_blend_minmax
	GL_EXT_blend_subtract
	GL_EXT_compiled_vertex_array
	GL_EXT_depth_bounds_test
	GL_EXT_direct_state_access
	GL_EXT_draw_buffers2
	GL_EXT_draw_instanced
	GL_EXT_draw_range_elements
	GL_EXT_fog_coord
	GL_EXT_framebuffer_blit
	GL_EXT_framebuffer_multisample
	GL_EXT_framebuffer_multisample_blit_scaled
	GL_EXT_framebuffer_object
	GL_EXT_framebuffer_sRGB
	GL_EXT_geometry_shader4
	GL_EXT_gpu_program_parameters
	GL_EXT_gpu_shader4
	GL_EXT_import_sync_object
	GL_EXT_multi_draw_arrays
	GL_EXT_packed_depth_stencil
	GL_EXT_packed_float
	GL_EXT_packed_pixels
	GL_EXT_pixel_buffer_object
	GL_EXT_point_parameters
	GL_EXT_provoking_vertex
	GL_EXT_rescale_normal
	GL_EXT_secondary_color
	GL_EXT_separate_shader_objects
	GL_EXT_separate_specular_color
	GL_EXT_shader_integer_mix
	GL_EXT_shadow_funcs
	GL_EXT_stencil_two_side
	GL_EXT_stencil_wrap
	GL_EXT_texture3D
	GL_EXT_texture_array
	GL_EXT_texture_buffer_object
	GL_EXT_texture_compression_dxt1
	GL_EXT_texture_compression_latc
	GL_EXT_texture_compression_rgtc
	GL_EXT_texture_compression_s3tc
	GL_EXT_texture_cube_map
	GL_EXT_texture_edge_clamp
	GL_EXT_texture_env_add
	GL_EXT_texture_env_combine
	GL_EXT_texture_env_dot3
	GL_EXT_texture_filter_anisotropic
	GL_EXT_texture_integer
	GL_EXT_texture_lod
	GL_EXT_texture_lod_bias
	GL_EXT_texture_mirror_clamp
	GL_EXT_texture_object
	GL_EXT_texture_sRGB
	GL_EXT_texture_sRGB_decode
	GL_EXT_texture_shared_exponent
	GL_EXT_texture_storage
	GL_EXT_texture_swizzle
	GL_EXT_timer_query
	GL_EXT_vertex_array
	GL_EXT_vertex_array_bgra
	GL_IBM_rasterpos_clip
	GL_IBM_texture_mirrored_repeat
	GL_KHR_debug
	GL_KTX_buffer_region
	GL_NVX_conditional_render
	GL_NVX_gpu_memory_info
	GL_NV_ES1_1_compatibility
	GL_NV_blend_square
	GL_NV_conditional_render
	GL_NV_copy_depth_to_color
	GL_NV_copy_image
	GL_NV_depth_buffer_float
	GL_NV_depth_clamp
	GL_NV_explicit_multisample
	GL_NV_fence
	GL_NV_float_buffer
	GL_NV_fog_distance
	GL_NV_fragment_program
	GL_NV_fragment_program2
	GL_NV_fragment_program_option
	GL_NV_framebuffer_multisample_coverage
	GL_NV_geometry_shader4
	GL_NV_gpu_program4
	GL_NV_half_float
	GL_NV_light_max_exponent
	GL_NV_multisample_coverage
	GL_NV_multisample_filter_hint
	GL_NV_occlusion_query
	GL_NV_packed_depth_stencil
	GL_NV_parameter_buffer_object
	GL_NV_parameter_buffer_object2
	GL_NV_path_rendering
	GL_NV_pixel_data_range
	GL_NV_point_sprite
	GL_NV_primitive_restart
	GL_NV_register_combiners
	GL_NV_register_combiners2
	GL_NV_shader_buffer_load
	GL_NV_texgen_reflection
	GL_NV_texture_barrier
	GL_NV_texture_compression_vtc
	GL_NV_texture_env_combine4
	GL_NV_texture_expand_normal
	GL_NV_texture_multisample
	GL_NV_texture_rectangle
	GL_NV_texture_shader
	GL_NV_texture_shader2
	GL_NV_texture_shader3
	GL_NV_transform_feedback
	GL_NV_vertex_array_range
	GL_NV_vertex_array_range2
	GL_NV_vertex_buffer_unified_memory
	GL_NV_vertex_program
	GL_NV_vertex_program1_1
	GL_NV_vertex_program2
	GL_NV_vertex_program2_option
	GL_NV_vertex_program3
	GL_S3_s3tc
	GL_SGIS_generate_mipmap
	GL_SGIS_texture_lod
	GL_SGIX_depth_texture
	GL_SGIX_shadow
	GL_SUN_slice_accum
	GL_WIN_swap_hint
	WGL_EXT_swap_control
Implementation Dependent OpenGL Limits:
Maximum Fixed Function Texture Units:	4
Maximum DrawElements Vertices:	1048576
Maximum DrawElements Indices:	1048576
GLSL:
Maximum Varying Floats:	60
Maximum Vertex Attributes:	16
Maximum Vertex Uniform Components:	4096
Maximum Fragment Uniform Components:	2048
Maximum Vertex Image Units:	32
Maximum Fragment Image Units:	32
Maximum Pipeline Image Units:	96
Cycles:
CPU device capabilities: SSE2 SSE3 SSE41
OpenCL device capabilities:
Number of platforms: 1
Platform #0
	Platform Name: NVIDIA CUDA
	Platform Vendor: NVIDIA Corporation
	Platform Version: OpenCL 1.1 CUDA 6.5.51
	Platform Profile: FULL_PROFILE
	Platform Extensions: cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d9_sharing cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts
	Number of devices: 1
		Device: #0
			Device Name: GeForce 9600 GS
			Device Vendor: NVIDIA Corporation
			Device OpenCL C Version: OpenCL C 1.0
			Device Profile: FULL_PROFILE
			Device Version: OpenCL 1.0 CUDA
			Device Extensions: cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d9_sharing cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts  cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics
CUDA device capabilities:
	GeForce 9600 GS
		CU_DEVICE_ATTRIBUTE_MAX_THREADS_PER_BLOCK			512
		CU_DEVICE_ATTRIBUTE_MAX_BLOCK_DIM_X			512
		CU_DEVICE_ATTRIBUTE_MAX_BLOCK_DIM_Y			512
		CU_DEVICE_ATTRIBUTE_MAX_BLOCK_DIM_Z			64
		CU_DEVICE_ATTRIBUTE_MAX_GRID_DIM_X			65535
		CU_DEVICE_ATTRIBUTE_MAX_GRID_DIM_Y			65535
		CU_DEVICE_ATTRIBUTE_MAX_GRID_DIM_Z			1
		CU_DEVICE_ATTRIBUTE_MAX_SHARED_MEMORY_PER_BLOCK			16384
		CU_DEVICE_ATTRIBUTE_SHARED_MEMORY_PER_BLOCK			16384
		CU_DEVICE_ATTRIBUTE_TOTAL_CONSTANT_MEMORY			65536
		CU_DEVICE_ATTRIBUTE_WARP_SIZE			32
		CU_DEVICE_ATTRIBUTE_MAX_PITCH			2147483647
		CU_DEVICE_ATTRIBUTE_MAX_REGISTERS_PER_BLOCK			8192
		CU_DEVICE_ATTRIBUTE_REGISTERS_PER_BLOCK			8192
		CU_DEVICE_ATTRIBUTE_CLOCK_RATE			1250000
		CU_DEVICE_ATTRIBUTE_TEXTURE_ALIGNMENT			256
		CU_DEVICE_ATTRIBUTE_GPU_OVERLAP			1
		CU_DEVICE_ATTRIBUTE_MULTIPROCESSOR_COUNT			6
		CU_DEVICE_ATTRIBUTE_KERNEL_EXEC_TIMEOUT			0
		CU_DEVICE_ATTRIBUTE_INTEGRATED			0
		CU_DEVICE_ATTRIBUTE_CAN_MAP_HOST_MEMORY			1
		CU_DEVICE_ATTRIBUTE_COMPUTE_MODE			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_WIDTH			65536
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_HEIGHT			32768
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_WIDTH			2048
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_HEIGHT			2048
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_DEPTH			2048
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LAYERED_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LAYERED_HEIGHT			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LAYERED_LAYERS			512
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_ARRAY_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_ARRAY_HEIGHT			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_ARRAY_NUMSLICES			512
		CU_DEVICE_ATTRIBUTE_SURFACE_ALIGNMENT			256
		CU_DEVICE_ATTRIBUTE_CONCURRENT_KERNELS			0
		CU_DEVICE_ATTRIBUTE_ECC_ENABLED			0
		CU_DEVICE_ATTRIBUTE_TCC_DRIVER			0
		CU_DEVICE_ATTRIBUTE_MEMORY_CLOCK_RATE			500000
		CU_DEVICE_ATTRIBUTE_GLOBAL_MEMORY_BUS_WIDTH			192
		CU_DEVICE_ATTRIBUTE_L2_CACHE_SIZE			0
		CU_DEVICE_ATTRIBUTE_MAX_THREADS_PER_MULTIPROCESSOR			768
		CU_DEVICE_ATTRIBUTE_ASYNC_ENGINE_COUNT			1
		CU_DEVICE_ATTRIBUTE_UNIFIED_ADDRESSING			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_LAYERED_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_LAYERED_LAYERS			512
		CU_DEVICE_ATTRIBUTE_CAN_TEX2D_GATHER			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_GATHER_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_GATHER_HEIGHT			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_WIDTH_ALTERNATE			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_HEIGHT_ALTERNATE			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_DEPTH_ALTERNATE			0
		CU_DEVICE_ATTRIBUTE_TEXTURE_PITCH_ALIGNMENT			32
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURECUBEMAP_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURECUBEMAP_LAYERED_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURECUBEMAP_LAYERED_LAYERS			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE1D_WIDTH			4096
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_WIDTH			4096
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_HEIGHT			65536
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE3D_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE3D_HEIGHT			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE3D_DEPTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE1D_LAYERED_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE1D_LAYERED_LAYERS			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_LAYERED_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_LAYERED_HEIGHT			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_LAYERED_LAYERS			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACECUBEMAP_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACECUBEMAP_LAYERED_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACECUBEMAP_LAYERED_LAYERS			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_LINEAR_WIDTH			134217728
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LINEAR_WIDTH			65000
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LINEAR_HEIGHT			65000
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LINEAR_PITCH			1048544
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_MIPMAPPED_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_MIPMAPPED_HEIGHT			8192
		CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MAJOR			1
		CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MINOR			1
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_MIPMAPPED_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_STREAM_PRIORITIES_SUPPORTED			0
		CU_DEVICE_ATTRIBUTE_GLOBAL_L1_CACHE_SUPPORTED			0
		CU_DEVICE_ATTRIBUTE_LOCAL_L1_CACHE_SUPPORTED			0
		CU_DEVICE_ATTRIBUTE_MAX_SHARED_MEMORY_PER_MULTIPROCESSOR			16384
		CU_DEVICE_ATTRIBUTE_MAX_REGISTERS_PER_MULTIPROCESSOR			8192
		CU_DEVICE_ATTRIBUTE_MANAGED_MEMORY			0
		CU_DEVICE_ATTRIBUTE_MULTI_GPU_BOARD			0
		CU_DEVICE_ATTRIBUTE_MULTI_GPU_BOARD_GROUP_ID			0
Bastien Montagne (mont29) triaged this task as Needs Information from User priority.
You can try to downgrade your driver, in case you already have latest one installed… Otherwise, please:
  • Do not paste walls of text like that directly in reports/comments, such reports must be attached as text files instead.
  • Ensure both your OS and drivers are fully up-to-date (and use official GPU drivers, not those provided by windows or tablet/laptop maker or open source ones in linux distributions).
  • Try to start Blender in factory settings (--factory-startup commandline option) (this will ensure whether this is a userpref or addon issue or not).
  • Try to tweak your GPU driver settings (e.g. try different values between 'performance' and 'quality' if you have such slider, etc.).
  • Launch Blender from the command line with --debug-gpu option and attach as text file here any error printed out in the console (do not paste it directly in comment).
