Edit Mode - Vertex Slide & Edge Slide do not honor 'C' toggle. problem affects multiple edit mode tools (shear as well)
Ubuntu x64 17.10, GTX 1080
Broken: rBb85be88655c
Vertex slide and Edge slide do not honor the C hotkey
  1. Open attached blend file (or create plane and go into edit mode and select one vertex)
  2. press g, g, c
  3. notice how the vertex slide doesnt work.
  4. select a second vertex by holding down shift and right clicking on another vertex
  5. press g,g,c
  6. notice how it doesnt work
Please let me know if more precise steps are required.
Also effects other tools such as sheer (cant select x or y axis)
Carlo Andreacchio (candreacchio) renamed this task from Edit Mode - Vertex Slide & Edge Slide do not honor 'C' hotkey to Edit Mode - Vertex Slide & Edge Slide do not honor 'C' toggle. problem affects multiple edit mode tools (shear as well).Aug 2 2018, 8:07 AM
Hi, Has there been any progress on this bug?
Thanks
Carlo
Seems to have resurfaced.
Seems to work correctly, cannot reproduce.
Retested, it is to do with Blender2.7x keymaps
Philipp Oeser (lichtwerk) lowered the priority of this task from Confirmed, Medium to Needs Information from User.
@Carlo Andreacchio (candreacchio) : I have tested this with Blender2.7x keymap just now and it seems to work?
Please report back if this is still an issue for you, will mark as incomplete until we hear back...
Sorry for the late followup.
Had a look into it, it seems that the fix that was made by Campbell was only applied for Blender 2.8, it would be great if this fix was applied to Blender 2.7x aswell
Thanks
Carlo
Fixing in 2.7x requires porting more changes then just this fix, closing.
