Blender crash used Grease Pencil #56208
Reference: blender/blender#56208
Window 7, amd rodeon r7200
Blender 2.8 Hash:
ab49b7d739
when i selcwt object Grease Pencil and then selecting mode "Draw" the program close
Added subscriber: @zarco1794
system-info.txt
Added subscriber: @sambler
System
FreeBSD 11.2 amd64
blender version
branch blender2.8 hash
503866c681
I can add an empty grease pencil object and as I draw I see the stroke but when I release the mouse it disappears. Adding a suzanne grease pencil object crashes. Annotations work.
woops.. I got in too quick.
I get the above crash when starting blender2.80 with a previously saved startup config and workbenches, starting with --factory-startup works fine.
What was meant to resolve this, I don't see any change, now using
777e1b9654
Changed status from 'Resolved' to: 'Open'
Sorry, I missunderstood the message above and thought it was solved.
Today, we have done a change in how the context is managed and maybe is related to your error.
503866c681
Could you try blender --factory-startup to check if the error appears?
If does not work, please try tomorrow build to see if your error is related to the other errors.
A funcionado restaurando de fábrica el programa. No encuentro las paletas de colores, supongo que no se ha implementado. La versión Grease Pencil 2.8 Branch del 21 de marzo subida a la pagina GraphicAll.org tiene una interfaz bastante intuitiva, espero que se pueda volver a implementar esta ideas sobre esta versión.
commit
503866c681
was what I reported the crash on. Just checked again with45751065c0
- same. I'm also not 100% sure my crash is same as original reporter.Yes factory startup works right but having previous saved 2.80 startup crashes when using new GP object.
Annotations in all views work fine. New grease pencil objects don't, I can add an empty GP and drawing appears but disappears after releasing mouse, adding a GP monkey object crashes as above.
Just tested, by using a 2.79 startup and no crash, I guess if it is only caused by an early 2.80 alpha startup file, then maybe we could ignore my crash.
@zarco1794 The palette colors has been replaced with materials (see: https://code.blender.org/2018/07/grease-pencil-status-update/ for more info)
As the error is only if you use old user prefs, could we consider this bug as solved?
For me, the problem has been solved
Thanks @zarco1794
