Blender does not start up
Windows 10 64 bit Operating system and NVidia ge force gt 710 graphics card
Broken: 2.79. found bundled python C/...
Worked: did not work since I installed it.
Since I installed the software recently, It did not startup, when I click the software it shows as "found bundled python." and it closes immediately. I uninstalled and reinstalled it, but it didn't work.
Try to run blender from command line:
  1. Press Window Key + R
  2. Enter cmd and press OK button
  3. enter: blender --factory-startup
Verify the log and be sure to update your video driver.
Bastien Montagne (mont29) triaged this task as Needs Information from User priority.
I get the same issue using an NVIDIA GeForce GTX 1050 GPU using the latest 398.82 NVIDIA driver
my CPU is an i3 7100, my ram 8gb DDR4, i'm under Windows 10 Professional 64 bits
no error message when opening Blender, even on the cmd window, a white window appears some seconds then closes
I tried the opengl32.dll to see if it was due to the graphic card and it doesn't seem to be the case since even with this, it didn't work
the Blender Foundation directory doesn't exist in %APPDATA%
trying "blender --factory-setup" has the exact same effect and doesn't change anything
starting with "--debug-all"
showed this
"D:\Program Files\Blender Foundation\Blender>blender --debug-all
Switching to fully guarded memory allocator.
read file
Version 272 sub 2 date unknown hash unknown
ordered
OBCube
OBLamp
OBCamera
then closed immediatly after that
What about trying to run the portable (zipped) version instead of the one that comes with the installer?
Bastien Montagne (mont29) closed this task as Archived.
Am afraid we won’t be able to help you much here, that is most certainly an issue with your specific configuration… Some more hints:
  • Try to disable any running anti-virus.
  • Try to disable any custom input device (de-install their drivers even), like some graphic tablets, some 3D mice, etc.
Thanks for the report anyway.
