Setting Segments or Normal Strength in the new Bevel Modifier Crashes Blender #56287
Closed
opened 2018-08-09 23:20:07 +02:00 by Dan Pool · 13 comments
Windows 10 Pro 64Bit
NVidia P4000
All Drivers up to date
Broken: Blender 2.8 5b6dde2293
Worked: NA
Blender crashes when adjusting normal strength or segments once Normal Mode is set to "Face Area". This crash occurs whether the number is directly entered with the keyboard or if the slider is adjusted.
  • Open Blender, Select Default Cube
  • Add Bevel Modifier
  • Set Segments to "3"
  • Set Normal Mode to "Face Area"
  • Set Normal Strength to "1"
  • Watch Blender Crash
Note: Steps 3 and 5 can be reversed. In this case, with Normal Strength set to 1, adjust the segments count to a number other than one.
To reproduce in the blend file, go to the bevel modifier for the cube and adjust the Normal Strength up to 1.
Bevel Crash.blend
**System Information** Windows 10 Pro 64Bit NVidia P4000 All Drivers up to date **Blender Version** Broken: Blender 2.8 5b6dde22935 Worked: NA Blender crashes when adjusting normal strength or segments once Normal Mode is set to "Face Area". This crash occurs whether the number is directly entered with the keyboard or if the slider is adjusted. **Exact steps for others to reproduce the error** - Open Blender, Select Default Cube - Add Bevel Modifier - Set Segments to "3" - Set Normal Mode to "Face Area" - Set Normal Strength to "1" - Watch Blender Crash Note: Steps 3 and 5 can be reversed. In this case, with Normal Strength set to 1, adjust the segments count to a number other than one. To reproduce in the blend file, go to the bevel modifier for the cube and adjust the Normal Strength up to 1. [Bevel Crash.blend](https://archive.blender.org/developer/F4182732/Bevel_Crash.blend)
Author
Added subscriber: @DanPool
#56286 was marked as duplicate of this issue
#56367 was marked as duplicate of this issue
Author
I wanted to add that any other value for Normal Strength works without issue. For instance I can type 0.99 into the field and click the the right spinner value arrow and there is an instant crash.
Rohan Rathi was assigned by Brecht Van Lommel 2018-08-10 00:59:26 +02:00
Added subscriber: @deadpin
Dupe of #56286
Dupe of #56286
Added subscriber: @mont29
Please follow our submission template and guidelines, also read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
@RohanRathi will let you decide whether those are same reports or not (with #56286).
Please follow our [submission template and guidelines](https:*developer.blender.org/maniphest/task/edit/form/1/), also read [these tips about bug reports](https:*wiki.blender.org/wiki/Process/Bug_Reports), and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, **small and simple** .blend and/or other files to do so if needed, etc. @RohanRathi will let you decide whether those are same reports or not (with #56286).
Author
It looks like these are the same issue. #56286 = #56287. The other wasn't posted yet when I started my bug report. I didn't post a blend file since it was a single modifier added to the default cube, but if you guys need to save that little bit of time (I know these things add up) I'm editing the post now to get one attached.
Added subscriber: @Scaredyfish
Thanks, confirmed.
Thanks, confirmed.
Added subscribers: @RohanRathi, @howardt
Member
5 Participants
Reference: blender/blender#56287
