CPU names not reflecting dual CPU sockets #56364
Priority::High
Priority::Low
Priority::Normal
Status::Archived
Status::Confirmed
Status::Duplicate
Status::Needs Information from Developers
Status::Needs Triage
Status::Resolved
Type::Bug
Type::Design
Type::Report
Type::To Do
Reference: infrastructure/blender-open-data#56364
Looking at this -- https://opendata.blender.org/query/fastest-cpu
The AMD Epyc 7551 32 core score... is actually a dual socket score -- https://www.reddit.com/r/Amd/comments/970fqu/i_submitted_an_epyc_result_to_the_blender/
"Complete run took 15:26.06. Dual Epyc 7551 with 2x32 cores on a Supermicro board with 256 GB DDR4-2667 in 8 slots (only quad-channel per-CPU)."
This is misrepresented in the results, making the results look like a single CPU is that powerful instead of a dual socket configuration being that powerful.
Added subscriber: @candreacchio
Added subscriber: @mont29
Please follow our submission template and guidelines, also read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
Videos and/or links to external sites etc. are not acceptable as bug report (they can be provided as additional information only).
This is not a bug report in terms of blender. It has no .blend file. It is to do with the new OpenData Blender website. I cannot produce a small simple blend file.
If you want steps.
Added subscriber: @SemMulder
Closing this as this is implemented as part of the new website.
