Blender Benchmark crashing #56394
Priority::High
Priority::Low
Priority::Normal
Status::Archived
Status::Confirmed
Status::Duplicate
Status::Needs Information from Developers
Status::Needs Triage
Status::Resolved
Type::Bug
Type::Design
Type::Report
Type::To Do
5 Participants
Reference: infrastructure/blender-open-data#56394
System is Windows 7. GPU is GTX970.
Benchmark runs fine on CPU.
The first time I tried to do GPU quick test the Benchmark crashed.
When it crashed there was a pop-up saying the benchmark had crashed but I could still post my successes. Surely the failures are useful to you as well?
I decided to give it another go, downloaded and installed again. This time I was able to do a quick test of both CPU and GPU. I ran the full test with CPU and got a result . I then tried to do a full GPU test and it crashed again, this time tripping the CUDA memory forcing a GPU reset. This time there was no pop up message.
Finally, on the opendata site you are only showing the 5 fastest processors and giving no breakdown on specific GPU's. Essentially it tells me nothing about where my system sits.
Added subscriber: @piersyf
Added subscriber: @fsiddi
Hi Peter,
Could you please edit the report so that it only features the issue you encounter?
You can copy all the other suggestions and feedback over to the feedback forum. Thanks!
Added subscriber: @CarlsBad
I see the same issue on macOS 10.13.6 and Windows 10, and in my case it (seems to crash only when the test is running via AMD GPU (either dGPU or eGPU). Also I notice the test seems to fail at the same point (early in the Classroom image test) but without warnings or error dialogs afterward. The test just hangs and sits there on screen indefinitely, Mac and PC.
CPU tests so far always run through as expected and also I can get the test to run normally and finish on the PC, using an NVIDIA 10-series card connected via eGPU. Attempting test via NVIDIA dGPU on PC now. Will report back.
No crash on NVIDIA dGPU.
Added subscriber: @Rigoletto
I could make quick benchmark for my nvidia gtx660, after replaceing it with an gtx1660 ti the benchmark fails. I uploaded the crash if it helps.
With replacing changed driver from 38x to 440.
gtx660 works: https://opendata.blender.org/benchmark/fc4f165f-27c6-4bf2-9cc0-b052d556d31f
gtx1660 fails: https://opendata.blender.org/benchmark/e95e6c76-cec1-46a2-8d6a-7df382a6bbf4
Hi Peter, we just released an updated version of the Blender Benchmark Launcher. Can you give it a try?
I'm going to close the issue for now, feel free to create a new report if you encounter any new problem.
