Version Switch is not basing the lang links off the current version in url #56420
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#56420
The language switch should only be changing the but it seems to be also changing the version to whatever is the first in the json
Added subscriber: @Blendify
the JS works as intended, it's the JSON:
the version is extracted from the second column, because the theme var is a number (and not 'latest').
so there can't be '2.79' two times - it will take the first match.
((could be solved better by concating the label in the script - speed, etc.))
current:
right:
This issue was referenced by 4437
