Normal map shading errors in OpenGL
Windows 10 x64
AMD Radeon R9390X - Graphics card
AMD FX-8320 - CPU
Broken: All Blender versions
Adding a normal map to a model breaks the shading of the object.
Press "M" to toggle (mute/unmute) the normal map in the file and watch the shading change in the 3D view window.
Here is a video I recorded showing the problem in more detail.
youtube link
Brecht Van Lommel (brecht) triaged this task as Needs Information from User priority.
It's not clear to me what the bug is, muting the Normal Map node is supposed to change the shading. It is needed for converting the Tangent Space normal to a normal for shading, so if you skip that step the result will be wrong wrong.
The video shows a different .blend file so we can't test that. Can you attach the .blend file that has the bug and a render showing the wrong result it gives you?
This comment was removed by Jonas Pilo (ninthjake).
Sorry, my wording is bad. I know the shading is supposed to change but it looks like adding a normal map adds a layer of reflectivity to the model.
I cannot share the file I showed in the previous video but I put together a new file + video that much better shows the issue.
(Open in Blender 2.8)
And here is how it looks for me
This time I simply just added a blank image as the normal map and plugged it into the standard Principled BSDF in Eevee on a default unwrapped cube.
This issue is the different color management settings in Cycles and Eevee. For Eevee / viewport you need to change the color space in the image editor to be Non-Color Data as well.
I've added it to the list of settings to unify in T54659.
