Search code problem on OpenData.Blender website #56492
Priority::High
Priority::Low
Priority::Normal
Status::Archived
Status::Confirmed
Status::Duplicate
Status::Needs Information from Developers
Status::Needs Triage
Status::Resolved
Type::Bug
Type::Design
Type::Report
Type::To Do
2 Participants
Reference: infrastructure/blender-open-data#56492
Hello,
It seems to be a bug at https://mydata.blender.org/ after clic on "public link", the search engine seems to be out of order (we see code only).
Alas the same problem is found on each "search" of the website...
https://opendata.blender.org/query/device-type-count
https://opendata.blender.org/query/fastest-compute-device
https://opendata.blender.org/query/fastest-cpu
and so on...
Screen capture :
Hoping this helps !
Best Regards,
Guy
Added subscriber: @Alomphega
Added subscriber: @fsiddi
This actually the expected behaviour of the "view benchmark" page. The code that you see is the actual result of the benchmark.
We plan to add a description that better explains that, as well as some charts that show the result in context of the other results on the platform. Thanks for the feedback!
Ok, thanks for the answer, so... Why to show only the 5 fastest GPUs and CPUs and not all the tried ones ?
This could be very useful for all users, and more motivating to everybody trying the benchmark software, you don't think so ?
We definitely plan to provide some more in-depth metrics for certain results.
Check the rest rest of the work board to get an idea of what is coming next. In particular #56478 and #56323 will (at least partially) address your question. For the rest, there's #56320.
Thank you very much for your answers Francesco :-)
