Round trip Collada export/import mesh distorted #56516
6 Participants
Reference: blender/blender#56516
Ubuntu 18.04.1 LTS
NV134
Broken: 2.79b
Exporting animation using collada produces distorted mesh when importing it into Blender again.
my_test.dae
system-info.txt
Added subscriber: @cereszal-1
Importing/exporting animation into Blender using Colladato Round trip Collada export/import mesh distortedAdded subscriber: @StephenSwaney
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
A guideline for making a good bug report can be found here: https://wiki.blender.org/wiki/Process/Bug_Report
Marking as "Incomplete" until the requested information/data is provided.
Edited and updated. Included as much documents as possible.
About round trip with Collada:
In general this is not possible because the Collada format does not support all data that is needed by Blender. However there is one way to achieve a perfect round trip: by adding a tool specific collada profile. This would in theory allow the implementation of a perfect round trip experience.
But i wonder if such a usage scenario exists at all. A roundtrip from blender to blender certainly makes the least sense (you would better use blend files for this scenario). And a roundtrip that involves Blender plus another tool would need the other tool to fully support the blender collada profile. But that does not sound very practical.
About the reported distortions:
You may want to build the "collada" branch and check if it works for you. I updated that branch recently, so it should build out of the box. It might possibly have resolved your issues. But no promise :)
and also...
I am still reworking the collada exporter (for blender 2.8). So this report might become another test case. However, i already found that the export of rigged items is not at all simple because there are a few things to take care of like for example bone constraints and drivers.
Thanks Gaia!
I first experienced this issue when importing .dae files from Blender into Gazebo.
https://bitbucket.org/osrf/gazebo/issues/2489/collada-loader-failing-at-loading-blender
I did the roundabout trip to check where could the issue lie. I saw a few people addressing a similar issue so I suspected that it might be a collada.
Meanwhile, I'll check out that branch and also sent a bug report to Gazebo.
Added subscriber: @mont29
Archiving for now, we can always reopen if needed.
Hi, just want to update that I finally got around to building the branch.
First thing I've noticed (even building right out of master) was that there is no .dae import option.
Secondly, it didn't solve the problem.
I exported the model with better collada and imported it into my standard blender. The distortion was still there as well as in Gazebo. It looks like something to do with the binding info not stored despite I tried to adjust my export/import settings to do so.
About the collada branch: I was able to import your dae file by using the Collada importer from the collada branch. However there is something goin very wrong with the handling of the Object scaling and the related location animation curves. I reopen this task now.
There might be something wrong with the model as well. I'm using a rigged model from Mixamo (re-imported into Blender) downloaded in a .dae format.
I've noticed the scaling issues which wasn't successful when I tried to fix it.
I'm beginning to suspect that this is a Mixamo issue as the same distortion is reflected in Gazebo as well.
Apparently, Mixamo isn't very friendly to software out of 3dsmax and Maya.
However i want to understand where things go wrong. At best the Collada Importer should report back if there is an issue in the data. I won't be able to get to this before next week, so if you can find some additional time for this you might be able to prepare some super simple demo (to make the dae file as small as possible) :
Then i can inspect the collada file much easier.
ok, i found one thing that is odd: the hip bone uses a scale of 100 in the animation, while the model and armatures are all scaled down by 0.01 in object mode. I bet there is something going wrong with how scaling of pose bones is related to object scaling.
So probably you can get this to work by taking care to use a consistent scaling so that ideally your scales can all be 1 in your model, your armature, and your animation. But anyways i still am curious to look at what goes wrong here. I believe the Blender Collada importer should be able to handle this situation correct.
Update:
The bug is reproducible on this model using the standard collada exporter.
It's not from Mixamo, has no scaling issue, etc.
This model has no issues loading up on Gazebo.
The model used in the bug report was downloaded from Mixamo in a .dae format. When imported, there were no distortions but the scaling issue was still present.
Update:
Finally got to creating the cube model. Figured out the issue.
If the bone is not directly parented/connected to the chain of the rig but still a child (with the black dots), it will be imported differently.
On simpler models with lesser bones, it will take a min of 2 round trips to encounter the issue. Even the position of the entire model will start to change.
I've attached the simplest setup with a box where the collada export round trip was done twice. The position of the rig and the mesh had changed.
boom1.dae
I've also uploaded the original model directly exported from blender. You can see the position clearly within the mesh.
boom.dae
please can you add the blend file as well? And which Collada export options did you set?
Ok, just did another test and the issue goes beyond this.
Basically, any mesh with an armature gets exported differently.
Attached is a simple plane parented to a bone. The plane has not been moved. The bones are snapped to the corners and aligned to center, etc.
Upon the second round trip, the bone changes position. No animations were necessary.
I did this a few times and the results were the same.
Summary:
rig.blend
Sending you the other blend file where the rig is distorted after the second round trip.
rig1.blend
I've created a new bug report as the latest findings might not be the same bug, or it could be the very bug that is causing the distortion ultimately.
New bug report
Added subscriber: @GaiaClary
Added subscriber: @Blendify
I'm gonna consider this resolved see that your other report is closed also
