AddOn da OrtogOnBlender não instala #56556
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#56556
Broken: (example: 2.69.7 4b206af, see splash screen)
Added subscriber: @adrianocampos
Added subscriber: @StephenSwaney
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
A guideline for making a good bug report can be found here: https://wiki.blender.org/wiki/Process/Bug_Reports
Marking as "Incomplete" until the requested information/data is provided.
Added subscriber: @mont29
Please follow our submission template and guidelines, also read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
When you install the blender and add the OrtogOnBlender AddOn, an Error message appears:
Error
Back (most recent call last):
"/usr/share/blender/scripts/modules/addon_utils.py", line 331, in enable
d=import(module_name)
"/home/adriano/.config/blender/2.79/scripts/addons/OrtogOnBlender-master/init.py",line 24, in
n.FotogrametriaOpenMVG Import*
"/home/adriano/.config/blender/279/scripts/addons/OrtogOnBlender-master/FotogrametriaOpenMVG.py", line 9, in
export exifread
leNotFoundError: No module named 'exifread'
Added subscriber: @jenkm
This addon is not maintained by the Blender project, so for issues you should report to the authors of that addon.
