Object rotation increases render time more than 10 times.
Confirmed, NormalPublicTO DO
Tested with windows 7 64bit and windows 10 64bit.
CPU ryzen 5 1600
GPU GTX 780
RAM 8GB GDDR4
(bug appears on other computers too)
tested with 2.79 and 2.8
If I rotate object for about 45 degrees around Z axis render time increases more than 10 times.
But in preview mode there is no difference in render time before and after rotation.
just rotate the object on attached blend file around Z axis about 45 degrees and compare render times before and after.
10seconds for 2000 samples before rotation and about 10 minutes after.
I tryed this object with no light source, except AO and bug still exists. If i remove doybles from mesh and simplify it, it takes less time to render after rotation, but still much more, than before rotation.
Wow, what a weird file! I can confirm there are differences in render time, but could not figure out why. I tried with not light source, with a different camera, with a different world, with no materials.
Still the same problem, in some rotation it renders really fast, and then, the more I increase the rotation, the render time increases as well.
It also doesnt depend on the camera angle, since rotating the object and the camera together still produce the same issue. However, copying the object and the camera and pasting it in a different file seems to eliminate the problem. Weird!
Could you please send me that file, where u eliminated the problem. I had no success with transfering the object into new empty project, problem didn't dissapear.
Turns out, I was wrong. The issus got a bit better, but there still is a significant slowdown happening.
I have prepared a file with the default world, no lamps, just the 2 objects (camera and mesh from your file). There are 2 keyframes, on frame 1 it renders fast, and frame 2 it renders slow.
I have tested with latest master as well as 2.79a. So I would say, bug confirmed.
Sebastian Koenig (sebastian_k) lowered the priority of this task from 90 to 50.Aug 30 2018, 1:00 PM
Brecht Van Lommel (brecht) lowered the priority of this task from 50 to Normal.Aug 30 2018, 1:01 PM
Brecht Van Lommel (brecht) edited projects, added Cycles; removed BF Blender.
Brecht Van Lommel (brecht) edited a custom field.
This is a typical issue with raytracers, many long thin faces along one direction are difficult to fit well in a BVH unless the faces are aligned to the X/Y/Z axis.
I'll consider this a To Do item, maybe we can make the spatial splits handle this case better, but would not strictly consider this a bug since it requires different BVH algorithms.
Ah, thanks for the clarification! :)
Also, the workaround is to subdivide the object more so the faces are not so long.
Thanks for your comment, I tryed to subdivide my mesh along faces and render time decreased much.
but it seems to be a littlebit routine to subdivide :)
Could you please explain me a little bit more:
why there is no problem in preview mode?
BVH structure in preview and final render are different?
(dynamic and static) that's the cause?
Is it possible to final render with dynamic bvh?
LINK to blender stackexchange topic, for other users, who got this problem.
It's not possible to render with dynamic BVH currently.
In preview mode all objects have their own BVH which in this case is aligned with the faces. For final render we try to put as much as possible in one global BVH, and only multiple instanced objects get their own BVH. This is usually faster but backfires here.
