FBX Animation Action Export Issue
Closed, DuplicatePublic
-Windows 10
-NVidia GTX 1080 Founders Edition
Broken: 2.79b
I have a object in Blender that is rigged with 3 animations in the action editor. When exporting via FBX binary, only 2 of the three animation actions get exported. When exporting using FBX ASCII, all animations are exported correctly.
Download
  • I'm not sure if there's a better way to do this, but I've been converting .fbx binary files to JSON with this (command: conv.exe toConvert.fbx output.g3dj) to inspect the files.
  • Export the files using the built in Blender to FBX export function (binary). Convert to .g3dj using the utility, or inspect with another method. The FBX file does not contain all animations present in the .blend file.
  • Export the files using Blender FBX ASCII. Inspect the ASCII file using Notepad, all animation actions should be present (in this case: engage, disengage, fire).
Will Davies (x_tech) updated the task description. (Show Details)
