Compress File option is not preserved on Windows 10
Closed, InvalidPublic
Windows 10, different systems
2.79b
As the title says, the Compress File option is not preserved on Windows 10. It works as it should on Kubuntu 18.04 and Windows 7.
1: Create a Blend file. Save it with 'compress file' option turned on.
2: Close blender and reopen the file.
3: "Compress file" option is turned off.
Bastien Montagne (mont29) triaged this task as Needs Information from User priority.
That sounds very weird… does it also happen with factory settings (launching blender from command line with --factory-startup option )?
@LazyDodo (LazyDodo) maybe you can try and confirm that?
I finally found the solution for this issue. The problem occured, because I used a custom startup file saved with a previous version of Blender, and always loaded project files with option Load UI ticked off. After starting Blender with factory settings, setting all UI elements as desired, and freshly saving my startup file, the mentioned option is preserved as intended.
