"Save Buffers" doesn't allow saving the volume passes
Windows 10
Broken: 2.79 aa844ad676d (2018-09-12)
The volume passes can sometimes not be saved when "Save Buffers" is enabled.
Open the provided blend file and render it. This should create four OpenEXR files due to how it is set up in the node editor. All files are created, except for the volume passes.
If you disable "Save Buffers", the volume files are stored too.
IMPORTANT
I tried to reproduce this from scratch, but was not able to do so! I took a file where the issue occurred and removed all the assets from it.
Bastien Montagne (mont29) lowered the priority of this task from 90 to 50.
It’s not saved because there is no data at all (as can be checked with a viewer node), for both volume passes, when Save Buffer is enabled. @Brecht Van Lommel (brecht), guess that one is for you?
